when to change brake pads
stranger12
PostPosted: 11:04 - 15 Jul 2015    Post subject: when to change brake pads Reply with quote
Hi Guys,
When do you change your pads?
Wait until 10% or so is left or sooner ?
Is there any reduction in performance comparing a 100% pad with 20% pad for sake of example ?
The reason I ask is because my r6 seems to have lost his braking performance . I have bled the system, have upgraded it to braided lines and use a new castrol performance dot4 in the system.
I did the upgrades because I did want to do it and not to address the braking issue.
I have no concerns buying a pair of new pads and not tight but want to know the answer before buying a pair.
I think the current ones are sintered ebc .
I also apply brake cleaner to the discs once every two weeks to the discs and let it dry without washing it off and then ride.
thanks
SV650 Red
R6 Red
UrbanRacer
PostPosted: 11:09 - 15 Jul 2015    Post subject: Reply with quote
yea, usually the last 10-20% of the pads is when i start to consider buying new ones.
I've tried a few different pads.
EBC Sintered pads are good with decent life.
Carbone Lorraine HH pads give good performance but the life of them is considerably shorter than the EBC pads, also the brake dust they generate is phenomenal.
I find the OEM pads to be the best of both worlds, the downside is they tend to be bit more expensive.
stranger12
PostPosted: 11:20 - 15 Jul 2015    Post subject: Reply with quote
cool
anyone that has used brembo ?
do you think spraying brake cleaner on the disc is a good idea every now and then ?
SV650 Red
R6 Red
Baffler186
PostPosted: 12:45 - 15 Jul 2015    Post subject: Reply with quote
It can't hurt, but I would use a new (clean) microfibre cloth and clean them properly - when mine have been really dirty over winter then the spray just removes the top stuff which dribbles down to the bottom of the disc. The most important thing in my view is to take the calipers off and thoroughly clean them, re-grease the pins etc.
I haven't noticed significant fade in older pads, but I do change them when they are visually approaching the wear line. Not tried expensive sintered pads but by all accounts they bite harder but they can wear your disc quicker.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
stranger12
PostPosted: 12:58 - 15 Jul 2015    Post subject: Reply with quote
that seems like it has at least 40% or more left .
this is how mine looks like .
why did you change ?
SV650 Red
R6 Red
stranger12
PostPosted: 13:05 - 15 Jul 2015    Post subject: Reply with quote
ok cool ,
i was asking in case you identified a fault
SV650 Red
R6 Red
PostPosted: 13:20 - 15 Jul 2015    Post subject: Reply with quote
Just did the Nazi Tractor fronts, they had about 3-4mm left. They probably had another few thousand miles or so left in them (I'm normally ever so gentle), but they were just starting to wear unevenly because of the seized pins.
I was having to unseize the pins and change the seals it seemed a false economy - even for a Scootch - to not put new pads in while I was at it.
If you're thinking about it, you should probably do it.
CaNsA
PostPosted: 13:41 - 15 Jul 2015    Post subject: Reply with quote
Pro-tip
Brake fluid doesn't disappear or evaporate in to the ether.
When fitting new brake pads, top up the brake fluid to the MAX level (if there is one)
When the fluid level drops close to the MIN level marker, check and replace pads if needed.
RhynoCZ
PostPosted: 14:09 - 15 Jul 2015    Post subject: Reply with quote
stranger12 wrote:
cool
I do have Brembo pads, not the best pads in the world, but not bad either. Their performance is a bit different than what you get from different brake pads manufacturers, but it's a matter of getting used to something.
Yes, you can clean the discs, I do that after bleeding my brakes. Make sure you do have a brake cleaner, or a cleaner that does not damage rubber parts (your seals) in the calipers. Chain cleaners are also alright to use, since those are made not to damage rubber O-rings in the chain. Thumbs Up
stranger12
PostPosted: 08:06 - 16 Jul 2015    Post subject: Reply with quote
called ebc yesterday and they said double h sintered in not good for fast riding and I should use EPFA sintered pads for fast riding .
what is the equivelent of it in brembo ?
if you are doing fast riding , what pads do you use to ensure no brake fade or performance loss ?
Mine feels soft and weak after few minutes of fast riding in traffic.
I understand people say pad and dot4 is what matters .
I have dot4 castrol performance, ebc sintered pads, and braided lines from hel
SV650 Red
R6 Red
RhynoCZ
PostPosted: 09:03 - 16 Jul 2015    Post subject: Reply with quote
Brembo SA = The same compound Japs put into the calipers in the factory. The pads are not fading, but they just do not feel very sharp - might be my calipers, I got a new set, when I got the pads.
Brembo SC = The same thing, but takes a bit of time to warm up to work properly.
Brembo RC = Racing stuff, when it's cold it does not work.
Brembo CC = Carbon-ceramic compound, not sure why, but they are there.
I got the SA compound, thinking it will be the same as what I had there, well, it's not. It's not bad, but it's different from the Nissin pads I had there.
My mate has race stuff brake pad compound on his CBR 919, and when it's cold the front brake just doesn't give you the certainty, but when it gets warmed up, it's the best thing money can buy. BUT, to have fully working front brake, you really have to go fast and brake alot, which is not safe really, definitely not on the open road. Thumbs Down
TL; DR - SA would be the best for slow and fast riding.
c_dug
PostPosted: 11:16 - 16 Jul 2015    Post subject: Reply with quote
The last set of pads I bought were from DP brakes, they were by far the best pads I've had in terms of stopping power.
Obviously you don't get something for nothing and I'm sure there was more wear to the pads or disks than other pads, though I have to say I didn't notice either wear particularly drastically.
I recommend them anyway Thumbs Up
Old Git Racing
PostPosted: 13:43 - 16 Jul 2015    Post subject: Reply with quote
Wanted about £90 for a set of OEM Brembo pads for the ducati. Put SBS equivalent in instead and have no complaints at all. Powerful, fade free, good bite hot or cold, 40 quid.
OGR
The last post was made 11 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 91.33 Kb
