| kawasaki z400j |
 kawasaki z400j L Plate Warrior
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 12:36 - 06 Apr 2002 Post subject: rr |
how do you no theres a good spark and petrol if its not running????
when was the bike last on the road??
my dad had a similar prob after leaving his gixer1000 in the garage over winter.
he was starting the engine regularly but wasnt warming it up properly so his plugs became coated in lead from the petrol as it wasnt being burned off, he changed his 2 outer plugs because 1 of them is usualy the first to fire, after 10 minuts of running on 2cylinders the middle 2 both came back to life.
(im not absolutely sertain if the outer cylinders fire first but on the gixer1000 they are the only 1s u can get 2 without removing the airbox)
hope that helps:) ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| kawasaki z400j |
| craigT19 |
 Posted: 12:53 - 06 Apr 2002 Post subject: rr |
hmmm if the cylinder is getting wet it means that atleast some fuel is getting in, take your carb apart and clean it it sounds like there may be no air getting in to the fuel mix, then it should should start, then try raising the revs slowely if it splutters then that would suggest a problem with your needles.
all the best ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| kawasaki z400j |
| craigT19 |
 Posted: 13:08 - 06 Apr 2002 Post subject: carbs |
no idea i wouldnt evan atemp to take my nsr's or my cbr's carbs apart i have taken the nsr's off though when i de-ristricted it (it may be the same but it may not) the hoses should come straight off at the carb end there only nomally held on with a sort of clip but be shore to remember what each hose does and where it goes (i stuck coloured stickers on mine) as for the carb mine was only held 2 the cylinder with 2 bolts (again it may not be the same). i cant really tell you how much labour will cost cos it is different every where "but" i would go to a kwaka dealer or approved garage to get it done as there trained for your bike and there work is garanteed.
carbs them selves will probably cost atleast £60 pounds each depending on the make you go 4 its usualy best to keep the originals (im guesing here but is your bike an in-line 4??) ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| kawasaki z400j |
| craigT19 |
 Posted: 13:17 - 06 Apr 2002 Post subject: inline |
inline means the set up of the cylinders i was just checking how many cylinders you had.
some terms for ya
in line 4 ---- 4 cylinders in line
paralell twin --2 cylinders next to each other firing at the same time
v twin ------- obvious to cylinders in a v shape
its done on cylinders not carbs because carbs are different i.e i think its honda that put the carbs between the v and yamaha put them out side.
remember most wepons of tarmac destruction like the r1,gixer100 ect,ect are fuel injected, so dont have carbs at all.
back to your earlier problem its a shame keith walkers not on-line as hes like the local knowledge guru hes usually the person peeps goto with technical probs. (hes not often wrong too) ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| Ryan |
 Ryan Nitrous Nuisance
| kawasaki z400j |
| craigT19 |
 Posted: 13:23 - 06 Apr 2002 Post subject: :0 |
if that dont work threaten it with a lump hammer, or kick it a few times  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| Scooby |
 Scooby Scrappy Doo
 Posted: 13:24 - 06 Apr 2002 Post subject: lol |
Yeah either that or scrap it  ____________________ A big enough hammer fixes anything! |
| kawasaki z400j |
| kawasaki z400 |
 kawasaki z400 Guest
The last post was made 24 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
