Side stand leaning angle.
Tracer1234
PostPosted: 21:50 - 16 Jul 2015    Post subject: Side stand leaning angle. Reply with quote
Hi All, Just a random question, mainly for any Striple owners. Does anyone else find that it stands really upright when on the stand. It doesn't seem to lean over very far at all and I get worried about it when parked in certain places that isn't dead flat.
Any Ideas?
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
SQL
PostPosted: 22:44 - 16 Jul 2015    Post subject: Reply with quote
leave it in gear
Raffles
PostPosted: 23:36 - 16 Jul 2015    Post subject: Re: Side stand leaning angle. Reply with quote
Has your bike been 'lowered'?
Adjustable side stands are available, though they are costly. A cheaper option would be to remove the foot, lop off a section of side stand and weld the foot back on.
PostPosted: 23:39 - 16 Jul 2015    Post subject: Reply with quote
Leaving it in gear won't help much but it is something I do by habit.
I don't think the ST has ride height adjustment but you could also check if you're using the right amount of pre-load. It's unlikely you've got it completely unwound unless you are Dani Pedrosa. i.e featherweight.
A brief websearch mentions people cutting sidestands down and welding the foot back on.
Think I'd just keep a lookout for suitable parking spots with adverse camber. Gutters spring to mind. Smile
talkToTheHat
PostPosted: 23:47 - 16 Jul 2015    Post subject: Reply with quote
45 degrees to the road, back tyre touching kerb works well for finding sufficient lean and not having the bike roll away.
Bandit. does. everything.
Tracer1234
PostPosted: 09:10 - 17 Jul 2015    Post subject: Re: Side stand leaning angle. Reply with quote
Noob alert: how can i tell if it has been lowered? Smile
PostPosted: 09:21 - 17 Jul 2015    Post subject: Reply with quote
Go into your nearest Triumph dealers and ask them for a short stand. They should have you sorted out within 5-10 minutes.
A100man
PostPosted: 20:13 - 17 Jul 2015    Post subject: Reply with quote
A short stand's no good, The man needs a longer weight I'd have thought.
PostPosted: 20:17 - 17 Jul 2015    Post subject: Reply with quote
Known issue with Hayabusas. Most people grind/file the stop a little so the stand swings further forward. Makes the bike lean a bit further and makes the bike much less likely to roll off the stand.
ADAMH0
PostPosted: 21:20 - 17 Jul 2015    Post subject: Reply with quote
Great advice
Excellent advice
This would work really well (provided you have have access to an angle grinder and a supply of sparks, available here if needed: https://www.david.zen.co.uk/toolstore/Online_Catalogue_Consumables_3.html )
I've also heard of a technique involving bending/manipulating the original stand using heat and a special glass hammer until you get the required angle....
The last post was made 10 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 68.8 Kb
