heavy clutch lever
ocatoro
PostPosted: 04:22 - 16 Jul 2015    Post subject: heavy clutch lever Reply with quote
morning all
just got my old zzr back and it's almost broken every tendon in my hand clutching on the way home. it used to get me a bit achy sometimes when i owned this bike before...
i'm likely just being a fanny, but is there anything that could make it painfully heavy? (i've ordered a new clutch cable to try that)
it also had new clutch plates before i bought it the first time a couple of years ago.
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
DrSnoosnoo
PostPosted: 08:58 - 16 Jul 2015    Post subject: Reply with quote
Is the pivot crusty and in need of a bit'o lube?
nowhere.elysium
The Pork Lord
PostPosted: 09:27 - 16 Jul 2015    Post subject: Reply with quote
Cable routing can have a surprising effect on how heavy the clutch feels.
Also, the nylon liner in the cable outer might have parted ways with the rest of the cable run, and fused to the cable.
Are there any pinch points on the cable run?
ocatoro
PostPosted: 00:27 - 17 Jul 2015    Post subject: Reply with quote
nah i think the pivot is ok...
i'm thinking it's just a combination of new clutch with good springs, and a slightly shagged cable... so will try that and see what's what.
talkToTheHat
PostPosted: 01:10 - 17 Jul 2015    Post subject: Reply with quote
a few drops of 10w40 worked through the cable works well. I just turn the top adjuster so the slot is facing up and pump the clutch whilst adding some oil from the can into the slot. You could get fancy and pressure lube but it's a pain in the ass, and spray lubes don't work as well.
Anyone tried one of the devices that force grease into a cable, are they any better or a recipe for sticky shite build-up at each end?
My clutch cable has a rubber boot at each end so I can run them quite oily.
Bandit. does. everything.
Old Git Racing
PostPosted: 07:53 - 17 Jul 2015    Post subject: Reply with quote
Please use something other than WD40, something like 3 in 1 oil is better.
Look on a can of WD40 and nowhere does it say lubricant. It is a water dispersing cleaner that eventually dries out and makes things worse.
New cable and routeing should sort it, if not is the clutch basket badly notched?
OGR
c_dug
PostPosted: 08:05 - 17 Jul 2015    Post subject: Reply with quote
https://i235.photobucket.com/albums/ee81/paddy2007dug/wd40_zpssiqvsdow.png
Just sayin'
Accuhaler
PostPosted: 18:00 - 17 Jul 2015    Post subject: Reply with quote
Just sayin'
He's right, it is right there in the name Water-Disdisplacer - 40th. fomula.
Even tho it says it on the tin, it won't last long and cause more issues then fix. Sure it's fine for a door hinge, but for something exposed to the elements on a daily basis it's a bad choice.
After all you don't see WD being used on Aircraft or Submarines now do you?
talkToTheHat
PostPosted: 15:08 - 18 Jul 2015    Post subject: Reply with quote
I did say 10w40 not WD-40. To be specific I use the the same JASO-MA2 10w40 engine oil that goes in the bike. Owners manual recommends 10w30 for general lubrication, but same manual also suggests I mess about with 10w30 in the winter and 20w40 in the summer. 10w40 for the win.
Old Git Racing
PostPosted: 18:01 - 18 Jul 2015    Post subject: Reply with quote
You did, my bad.
OGR
PostPosted: 20:00 - 18 Jul 2015    Post subject: Reply with quote
Embarassed My bad rating as well. Sorry, we recently had that Acerman special sperging "WD-40" as the panacea for everything, I'm still a bit twitchy over anything with 40 in it.
Bru
PostPosted: 20:10 - 18 Jul 2015    Post subject: Reply with quote
It may also help to drop the lever down (by rotating it 'forward') a bit, if you can. That will line it up better with your wrist when you close your hand over the lever.
The last post was made 11 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 74.3 Kb
