| sutty86 |
 sutty86 Trackday Trickster
 Posted: 08:36 - 17 Jul 2015 Post subject: |
You need to fix the reason why.
If the nut is done up tight, the most likely culprit is failed wheel bearings which would need replacing with a degree of urgency wether the MOT is due soon or not.
"Only a mm or two" is a dangerous way to think. There should be NO lateral play on either wheel at any time, any evidence of such play is your cue to get it sorted. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Taught2BCauti... |
 Posted: 08:37 - 17 Jul 2015 Post subject: |
Hard to say without knowing make/model/year, but generally a sign that you need to inspect the rear wheel bearings immediately, and change them if they are worn.
Could be a cheap and easy DIY job, or an expensive dealer only job. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| sutty86 |
| MarJay |
 MarJay But it's British!
| sutty86 |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 18:31 - 17 Jul 2015 Post subject: |
Is this 2mm of wiggle in the wheel rim, or 2mm the wheel slides on the spindle.
If wiggle at the rim then probably a dead wheel bearing. But check the spacers to ensure they are not missing, which will wreck a bearing rapidly.
If sliding on the spindle then probably a missing spacer. But potentially also a very badly worn swinging arm preventing the spindle from doing up tightly (ie, the spindle runs out of thread before it clamps the wheel); only seen this once though.
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| kramdra |
 kramdra World Chat Champion
| Teflon-Mike |
 Posted: 13:32 - 18 Jul 2015 Post subject: |
| Kickstart wrote: | Hi
K |
^^^^ This + Check the simple/obvious first.
If wire spoke wheel... check the spoke tension! Make sure wheel is true. Look at the spoke holes in rim and hub, make sure that the holes haven't fretted letting spokes go sloppy and rim walk around over the hub.
ALSO... and its a real 'Duh' one... the spindle nut tightens!
There's usually a dimple on the middle of the spindle, so that when you want to take the wheel out, if the spindle's a bit stiff... which if you have a bike with no center stand, and less than 'bright' spanner-monkey is trying to take it off without supporting wheel off the floor, it will be.... you can pop a taper-drift into the dimple to give it a wack.. course, sort of spanner-monkey who tries taking a wheel out without supporting it off the floor, is more likely to just wack the end of the spindle.... resulting in mashing the 'lead-in' and possibly the first couple of turns on the thread.... when put back together the nuts a bit hard to start.. but will often still go on... ONLY, the deformed treads can tap out the threads in the nut... BUT can still wind down the rest of the thread, probably rather tightly; but 'stiff' easy to think it's 'tight' without actually squashing swing-arm onto the spindle spacers, or for the nut to be stripped enough it wont put pressure to squash the swing-arm plates in.
Check rest of spindle assembly while you are looking; some swing-arms have pinch-bolts that have to be done up one end, before the spindle-nut, or it all stays loose, chain adjuster's can be fitted wrong or cocked, or slip, and again, stop the wheel being clamped up properly.
Wheel bearings tend to be pretty reliable, these days, especially as many are 'sealed' pre-greased units, and on a lightweight not that highly loaded. I'd only suspect them to be a more likely candidate if the thing has been sore used off-road, and they have been filled with muddy or salty water regularly, or the things been left derelict in partially dismantled state... so not the first conclusion I would jump to, as far as culprit & cure. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 10 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
