Bike jerking and lose of power.
Kiingyy
PostPosted: 15:37 - 17 Jul 2015    Post subject: Bike jerking and lose of power. Reply with quote
Hey, I have been riding for about a 2 weeks now on a brand new Lexmoto Venom 125cc, When i try accelerating (even when moving off from traffic lights) my bike jerks slightly and i lose some power, it has been doing this since i had the bike serivced yesterday, Anyone have any thoughts on it? Would be awesome to know as im brand new to riding, I know the bike is chinese but surely problems shouldn't occur this early into getting it, I have only done about 230 miles.
Thanks
New to biking and need any advise.
B0ndy
PostPosted: 17:00 - 17 Jul 2015    Post subject: Reply with quote
What did the service involve?
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
delsol
PostPosted: 17:35 - 17 Jul 2015    Post subject: Re: Bike jerking and lose of power. Reply with quote
Thanks
It does not matter who makes it or how new it is, I have had problems with brand new 'quality' brand equipment before.
Back to dealer, let them sort it, and try to find out what "actually" caused the problem.
Learn some basics on bike maintenance, or shop around and AA\RAC etc. cover is damn cheap and conveniently re-assuring.
Kiingyy
PostPosted: 17:38 - 17 Jul 2015    Post subject: Reply with quote
They changed the engine oil and the Oil filter, Tightened my chain cause they said it was lose and cleaned the spark plugs.
delsol
PostPosted: 18:42 - 17 Jul 2015    Post subject: Reply with quote
There you go, cretins were allowed to 'clean' your spark plug, do not let this happen again, clean your own spark plug.
Always carry spare plug and key, it's the least you can do to give yourself a chance to keep on rolling.
Kiingyy
PostPosted: 19:30 - 17 Jul 2015    Post subject: Reply with quote
Sorry but i am very new to riding and know next to nothing about, Bikes, I have no idea how to change/clean spark plugs or where they are or what they look like. I know im an Amateur but we all have to start somewhere. And also how would cleaning spark plugs effect how my bike accelerates?
delsol
PostPosted: 20:18 - 17 Jul 2015    Post subject: Reply with quote
Understood, but I take it you have a user manual for the bike, at the very least I would expect that it would illustrate how to change a spark plug, give the spark plug type and the recommended gap.
I suggest you try changing a plug, you will be surprised how easy it is, you don't need to bother about gapping or even cleaning plugs, just have spare(s).
https://www.youtube.com/watch?v=VPm_Z92FgCw
Mysteriass
PostPosted: 20:40 - 17 Jul 2015    Post subject: Reply with quote
The spark plug is creating a gap in a timed on/off electrical circuit (timing). When the power in the circuit meets the spark plug it is forced to (sp)arc over the gap. This arc of HT (High Tension) power is what ignites the fuel in the cylinder barrel that the carb or injector just put there. When the fuel ignites it pushes the piston down which turns the motor.
The spark plug has to be clean in order to have good electrical contact between its gap. If it gets covered in shit, the bike will run like shit.
Possible that they've altered the gap (place where the electric arcs) in the plug when they cleaned it. That gap may also affect the performance of your bike. The idea is to have a BIG spark but not so big that the ignition circuit from the coil doesn't want to bridge the gap. You also don't want a small gap that makes a small electrical (sp)arc and won't ignite the fuel so efficiently.
Be careful with the plug when replacing it if you take it out. The head is made of alloy, that means you can strip it with very little torque. Screw it in finger-tight, gently, making sure not to cross thread it. Then get a plug spanner on it and just give it a...just make it feel "right". Screwing anything into alloy requires little more than finger tightness and it's very easy to cross thread so you need to get a feel for that.
The last post was made 10 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 57.09 Kb
