DT help
Laura
Playboy Bunny
PostPosted: 15:17 - 04 Feb 2005    Post subject: DT help Reply with quote
Right help with DT needed Alex brought this dt about 4/5 months ago he heard it running and then it died. Toko petrol tank of and it was full of rust. It has been standing for about 4 months since and now has a new petrol tank on and the carbs cleaned.
The spark is fine n the bike and we have tried bumping etc, It fires but wont run.
Good girls ride motorcycles bad girls thrash them.
Scotsman37
PostPosted: 15:46 - 04 Feb 2005    Post subject: Reply with quote
Have you checked out the ignition pulse generator to see if the timing rotor is damaged or the generator coil is faulty?
Laura
Playboy Bunny
PostPosted: 15:47 - 04 Feb 2005    Post subject: Reply with quote
Scotsman37 wrote:
Have you checked out the ignition pulse generator to see if the timing rotor is damaged/worn ?
Lol what english please!
Scotsman37
PostPosted: 15:50 - 04 Feb 2005    Post subject: Reply with quote
Is there no Haynes manual available for your bike as it will tell you how to check for this.
Laura
Playboy Bunny
PostPosted: 15:52 - 04 Feb 2005    Post subject: Reply with quote
Ill ask g and dusty then.
PostPosted: 17:54 - 04 Feb 2005    Post subject: Reply with quote
That it sparks tends to suggest the ignition system is OK. Yes they can have problems but most of the time they either work or they do not. However one thing worth checking is the ignition timing, as the flywheels are located with a woodruff key and these can shear off allowing the flywheel to move a bit. Result is a healthy spark at totally the wrong time.
Beyond that I would say that a carb / fuel issue is the most likely. Clean the carb out again. Also check the reed valves are sealing correctly (easy to whip those out while the carb is off).
Also worth doing a quickly compression check. Not unknown for piston rings to strick when a bike is left standing for a while. Although this is unlikely it is an easy check to do.
simon1221
PostPosted: 17:56 - 04 Feb 2005    Post subject: Reply with quote
I know there is a haynes manual for the 1987 - 1993 Dts and the post 1997 ones.
PostPosted: 19:23 - 04 Feb 2005    Post subject: Reply with quote
Could it be that the breather hose or the fuel line is blocked with rust?
If there is an air lock or part blockage somewhere, some fuel will get through and build up in the carbs. The bike will fire, but then the fuel will run out and the engine will die.
I suggest trying to clean out every tube that was ever connected to the old tank.
Also check the carbs are set up to provide enough fuel to the engine. I think there might be some sort of needle adjuster for the main jet...
Whitetrash This post is not being displayed because the poster is banned. Unhide this post / all posts.
Scotsman37
PostPosted: 13:24 - 06 Feb 2005    Post subject: Reply with quote
On your bike it's called the Magneto Rotor.
Do what the other have suggested and check/replace fuel line hose as they maybe clogged with that rust and so it's severely restricting the flow of fuel but you may end clogging the carbs again when the particles of rust along with some fuel get into the carbs and clog up the jets.
Once yoy've removed the fuel line you could try using a high pressure jet of air through it to see if any crap comes out of it, but then you may have still got clogged up carbs except thats disassembly job of it to inspect it.
The last post was made 21 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 3.93 - MySQL Queries: 13 - Page Size: 65.39 Kb
