Strange squeek when braking/turning
Doomsnite
PostPosted: 20:54 - 18 Jul 2015    Post subject: Strange squeek when braking/turning Reply with quote
When braking on the rear brake at very slow speeds and turning, there is a strange short, repeating squeek/squeal and i cant figure out what it is. Has only happened since i stripped the front end off and put a new rear disk on.. Any ideas?
Thought it could be something warped and rubbing but weird it only happens with the bars turned!
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
Benjums
PostPosted: 08:36 - 19 Jul 2015    Post subject: Reply with quote
Could it be some bearing on the way out? Headstock? Bearing or wheel bearing starting to give up the ghost?
Taught2BCauti...
PostPosted: 09:36 - 19 Jul 2015    Post subject: Reply with quote
Could be that the pads are catching slightly, and if there's a small amount of play in your rear wheel bearings, this will be noticeable when you turn.
Check the rear wheel bearings for excessive play, and the rear caliper as it may need stripping, cleaning, new seals, etc.
Also check that the pads are wearing evenly and squarely - i.e not forming themselves into a wedge shape, or one side wearing down more than the other.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Val
PostPosted: 11:36 - 19 Jul 2015    Post subject: Re: Strange squeek when braking/turning Reply with quote
The rear brakes squeal because the back of the brake pads reverberate with the piston. Obviouly in your case that happens only when applying slight side force on the wheel when turning.
That is annoying but a non probem if the pads are wearing evenly. You can ignore it or the way to cure that is:
1. Some pads have anti-squeal metal shims also including metal plate on the back.
2. Put some copper brake grease on the back or even better this one:
https://www.amazon.co.uk/gp/product/B007D3H5G4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01
Doomsnite
PostPosted: 21:09 - 19 Jul 2015    Post subject: Reply with quote
Cheers. Think ill check if wearing evenly. Its not annoying so could live with it if its not a problem
The last post was made 10 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 44.54 Kb
