NSR 125 Wiring/ignition
lynnnsr
PostPosted: 13:17 - 19 Jul 2015    Post subject: NSR 125 Wiring/ignition Reply with quote
The bike ran fine up until Friday. Then, I disconnected and reconnected all of the connectors at the front of the bike to allow the front headlights and fairings which had been removed to be refitted. Now - won't start!
Turn on key, neutral and stand lights come on. They both go off as usual if a gear is engaged or stand goes up. Tested starter button and kill switch, and their connections back through the wiring, they both work.
But if I press the starter, nothing happens. If I try to bump start it, it won't start. So I reckon whatever circuit stops the starter and the ignition from operating, must be incomplete somehow.
Checked all the other connectors, can't find anything wrong/disconnected or obvious loose connections.
Where do i go from here? Like I said, all working fine until I disconnected and reconnected all the wiring plugs under the ignition/behind the headlights the other day.
NSR 125 (with L-Plates) > 1994 NTV 650 > 2015 CB650F > 16 VFR800F
alains
PostPosted: 14:54 - 19 Jul 2015    Post subject: Reply with quote
the ignition is totaly independent of the rest
so if the bike dont bumpstart the problem is elsewhere
the starter is directly connected to the battery but the relay isnt , check it , check if the black of the relay has 12V (with the ground)
lynnnsr
PostPosted: 16:33 - 19 Jul 2015    Post subject: Reply with quote
Thanks,
OK - no voltage across the two small wires at the relay (no black wire there) when starter pressed.
Where next?
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
lynnnsr
PostPosted: 18:12 - 19 Jul 2015    Post subject: Reply with quote
Neither of the small wires on the relay is connected to ground.
Which one should be?
I have green/white and red/yellow.
There in fact is a spark at the plug. Wouldn't bump start as no fuel. Different problem as alains said. So just need to get the starter turning now.
alains
PostPosted: 19:02 - 19 Jul 2015    Post subject: Reply with quote
download the wiring here https://www.geneva-racing.ch/~alains/schema_R.jpg
alains
PostPosted: 15:16 - 20 Jul 2015    Post subject: Reply with quote
sorry about my mistake
the wires feeding the starter are RED & RED/WHITE
the starter coil are red/yellow & green/white
the red/yellow is the +entry and the green/white is the exit going to a ground through a diode for security
to test the relay : connect the entry to a + 12V and exit to the ground , you shoud hear the coil making a noise
lynnnsr
PostPosted: 21:06 - 20 Jul 2015    Post subject: Reply with quote
Now solved this.
I'd plugged the 4 way connector for the headlights into the 4 way connector from the starter button. No wonder it wouldn't work.
I took it for granted that the connectors would all only fit back in the correct ones, like with most modern machinery, so a lesson learned I think.
Thanks for the help.
The last post was made 10 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 55.79 Kb
