Scottoiler Vacuum Tubing
b422063
PostPosted: 06:16 - 22 Jul 2015    Post subject: Scottoiler Vacuum Tubing Reply with quote
It appears at some point my Scottoiler "delivery" end has met my sprocket, argued and lost the fight.
I can get the clear tubing from B&Q, but does anyone know where I can get the vacuum tubing from (other than Scottoiler themselves, as it's relatively expensive).
Thanks
PostPosted: 10:17 - 22 Jul 2015    Post subject: Reply with quote
It's standard (albeit unusually thin) nylon pneumatic hose. It's usually used for pneumatic control circuits.
If it's just for the delivery end, I'd suggest the straw off a WD40/chainlube can...
smallfrowne
PostPosted: 10:22 - 22 Jul 2015    Post subject: Reply with quote
Hmm I'd go to my local bike parts shop, but failing that maybe a motor factors would have some.
Edit: since it's standard pneumatic tube, if it was me I'd try my luck at the hydraulics place down the road - all types of hose available from them.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
PostPosted: 10:34 - 22 Jul 2015    Post subject: Reply with quote
If it's somewhere that makes pneumatic control circuits, they'll have offcuts long enough to make scotoiler delivery tubes lying around on the workshop floor all over the place.
My Dads old company built pneumatic lifting equipment and we used to go through miles of the stuff, you wouldn't have bothered putting a bit of hose less than 6" long back on the shelf.
Oldie
PostPosted: 10:49 - 22 Jul 2015    Post subject: Reply with quote
Scottoiler are based in Milngavie. 0141 955 1100
Call them and they'll help you out (maybe even for free). Always been very helpful when I've need help.
b422063
PostPosted: 13:43 - 02 Aug 2015    Post subject: Reply with quote
Does anyone know where I can locate 3mm OD flexible piping from? Confused
PostPosted: 13:46 - 02 Aug 2015    Post subject: Reply with quote
www.ebay.co.uk/sch/i.html?_nkw=3mm+pipe
b422063
PostPosted: 15:22 - 02 Aug 2015    Post subject: Reply with quote
<sarcasm>Gee, thanks, I didn't think to look there. Rolling Eyes </sarcasm>
List a specific item if you've found one otherwise they're all 3mm ID.
PostPosted: 15:44 - 02 Aug 2015    Post subject: Reply with quote
Ah, my apologies, didn't notice the OD bit and didn't recall the Scottoiler requiring an OD rather ID specific pipe for it's vacuum tube.
So, to continue on the theme Smile...
https://www.google.co.uk/search?q=3mm+od+flexible+tube
Stalk
PostPosted: 07:54 - 03 Aug 2015    Post subject: Reply with quote
Try old fashion advance and retard pipe which you may get from an old fashion motor spares shop
MCN
PostPosted: 11:55 - 03 Aug 2015    Post subject: Reply with quote
Vincent wrote:
Pet shop.......fish section Thumbs Up
Not the same.
Simple painless solution is to contact Scotoiler (like as was said ages ago but ignored by the OP).
Penny Pinchin' gets as Penny Pinchin' does. Razz
MCN
PostPosted: 17:05 - 03 Aug 2015    Post subject: Reply with quote
Vincent wrote:
As what?
I have fish tanks with multiple air-stones and air pumps. The clear tubing (that is in the tank) gets very hard and is a thing I have replaced regularly.
I have Scotoilers on three bikes and I haven't had to replace the tubing due to it getting hard.
Some tubing is Vinyl and some is Silicone it all 'looks' the same but different properties.
You can get a roll of the supply tubing from SO for about a £5 and the delivery tubing is £3
The Black Injector tubing that 'almost' touches the sprocket (which looks like Nylon Pneumatic/Hydraulic hose/pipe) £3
Last time I bought a roll of fish tank tubing I think it was about a 5-er.
Scotoiler are very helpful and have always did me favours. They support their product.
Just sayin', rather than phaph for a month call the OEM and ask. Karma
b422063
PostPosted: 19:30 - 03 Aug 2015    Post subject: Reply with quote
OP stated this in the first post. Yes I could just buy it from Scotoiler, but it's extortionate. It's the same reason I don't use their oil.
I'd love to support businesses but not at any cost. There a recession on you know! Wink
The last post was made 11 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 86.61 Kb
