| von1papen |
 von1papen Spanner Monkey
 Posted: 10:56 - 22 Jul 2015 Post subject: Enfield Bullet 350 mods/improvements |
So I've been busy fiddling with the Enfield getting it ready for its MOT (on its VIN).
In terms of modifications I've scrapped the K&N filter and fitted a bellmouth because it looks cool . I will invest in a tea caddy old style air filter for the winter. The carb has been supposedly upjetted but I haven't had it apart yet to confirm.
This also free'd up the toolbox as this is where the original air filter was.
Does any of the bullet owners have any experience of the Short 50's style exhaust as sold by Hitchcocks? I'd like to add this to complete the look.
It had a test run and I noticed the speedo was abit all over the place once you went above 30, I assume this is normal?
I like the idea of fitting a high comp piston and a 0.5mm headgasket, but I think I'll ride it for a season (or wait till I seize it) before I go stripping the engine.
What have the other bullet owners on here done? ____________________ Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:50 - 22 Jul 2015 Post subject: Re: Enfield Bullet 350 mods/improvements |
I'm back to the stock filter (with an Amal carb and unrestricted exhaust) because I find it runs better than a cone.
| von1papen wrote: | It had a test run and I noticed the speedo was abit all over the place once you went above 30, I assume this is normal? |
Mine's steady enough, but wildly optimistic. It's a good indication that you're travelling forwards and that's about it.
| von1papen wrote: | What have the other bullet owners on here done? |
Fiddled with the filter, jet, idle mixture, needle height, slide cutaway... then put it all back pretty much the way the previous owner had it set up and left it alone.  ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 12:13 - 22 Jul 2015 Post subject: |
Where to start?
What year is yours? Some of the later ones (like mine) has a serious crankcase breather design flaw that'll need addressing.
In terms of upgrades, some seem more or less worthwhile than others.
I'm running a cone filter and shorty (cheap Indian) exhaust on mine. It ran fine on the mikcarb with Hitchcocks suggested slide and jet changes.
I fitted the high(er) compression piston, made little to no real world difference.
I eventually knackered the head on it (due in part to the afore-mentioned breather problem) and fitted as tuned head so it would have been rude not to fit a big Amal at the same time...
I fitted a pair of high flow oil pumps shortly after I got it, lapped them in and and relieved the casting to allow them to move freely both ways. I also fitted a weaker spring to the scasvenge pump to allow it to bleed oil past if it over-pressurises.
The balanced samrat rockers are definately a worthwhile upgrade. When you see them next to the standard enfield ones you'll see why. Bike can rev noticeably higher and more quickly.
Because I have high flow pumps, I've fitted a pressure relief valve on the oil feed to the head and left the rockers with the o-rings in place as pressure fed.
If you have no pressure relief (some earlier ones had them as standard), it is more usual to miss out the o-ring and drill out the hole in the top of the rocker block a bit bigger so they are volume rather than pressure fed to keep strain on the pumps down.
I now have an alloy barrel because I broke the fins on the standard one trying to get the head off.
If you take the head off, fit the hardened washers under the head nuts. Consider fitting the studs with the square ends that can be undone and removed with the head in place. This makes removing the head for a de-coke MUCH easier.
I also have a lucas alternator stator and have retro-fitted a Kawasaki reg/rec because the standard regulator failed and took out the alternator.
I also fitted valve stem oil seals recently. Hitchcocks supply them for the standard head but not the tuned one. Mini 1100 valve stem oil seals fit the tuned head. Worth doing if you have the head off.
One thing definately worth doing is to replace all the copper crush washers on the oilways and drain plugs with dowty washers. Keeps it all oiltight.
I've fitted a slightyl modified gear selector mechanism and pawl (filed the notches out a bit better to match the pawl and filed the re-hardened the pawl to fit the notches better) after it started jumping out of first and took out a gear cluster.
I tried changing the gearing by adding a tooth on the engine sprocket but frankly, this was a bad idea and made it slower in the real world by making the gap between third and fourth a bit higher up meaning you have to stay in third up hills. I changed it back again.
I fitted the mainstand stop height adjuster to help prevent grounding.
Cosmetically, mine is now a rusty mess but it runs well. But I've fitted a sprung saddle, touring tank, rear luggage rack and some shorty mirrors.
Mine still burns an inordinate quantity of oil even with all the mods and despite drilling a breather hole in the crankcase. I'm pretty sure that's just down to the last-gasp and ill conceived breather design modifications they made to get the later models through emissions regulations.
https://i48.photobucket.com/albums/f216/stinkwheel/dragon2014/CIMG1496_zps06af63b4.jpg
EDIT: I'm on my third speedo. The damper spring broke in one which made it oscillate wildly. The needle broke off the second one due to vibration. They are a little usteady but mine doesn't waver much more than a 10mph arc at its worst. Try oiling the cable. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 12:23 - 22 Jul 2015 Post subject: |
Currently having fuelling issues with my Amal carb setup, but should be sorting those relatively soon (I hope). Previous owner rode through Hitchocks with the tart magnet on full.
https://www.bikepics.com/pics/2015/04/25/bikepics-2738190-full.jpg ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Matt B |
 Matt B World Chat Champion
 Posted: 12:32 - 22 Jul 2015 Post subject: |
Mine ended up looking like this.
https://i1077.photobucket.com/albums/w462/MattB70/IMG_2005_zps27afba1b.jpg
That's the swept back Goldstar style exhaust from Hitchcock's. It was very loud with the baffle out and made some nice burbling popping sounds on the overrun. Smaller indicators look nice and the rack was useful for lugging stuff around. ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| von1papen |
| stinkwheel |
 Posted: 13:43 - 22 Jul 2015 Post subject: |
You have the proper breather setup Just watch the catch-can for mayonaise build-up.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/DSCN0705.png
With the carb setup, it's all pretty rough and ready anyway and it's a piece of piss to get at to change stuff anyway. If you remember your starting point, you can always go back to it.
As I recall, I actually used mikuni componants (emulsion tubes, jets etc) when I re-jetted the mikcarb which seemed much better quality. I think I had a #2 slide, 100 jet and 27.5 pilot.
The replacement slide bound against a lip in the bore of my carb, I had to take a fine file and make a chamfer on it to stop it sticking. In fairness, the original one already had a chamfer. (original on right)
https://i48.photobucket.com/albums/f216/stinkwheel/slides.png
One other simple but useful mod is on the mainstand pivot. They have a habit of the mainstand and pin pivoting in the frame lugs instead of the stand pivoting around the pin like it's suposed to. This gradually ovals the holes in the lugs, the stand moves further and further back and eventually both wheels are touching the ground with the stand down (and it's a sod to get up onto the stand, it shouldn't be).
The fix is easy. Where there is currently a split pin, put a longer piece of wire through and bend the end over the spring mounting pin. This will prevent the pivot from rotating in the lugs. I used a bicycle spoke. Worth greasing the pivot while you're here.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/Image001.jpg
If it's already too far gone, you can weld a bit of flatbar to the stand so it hits the bump-stop sooner.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/Image000.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| von1papen |
 Posted: 13:10 - 30 Jul 2015 Post subject: |
Update!
She had a hissy fit going to the MOT centre
Lights went loopy, I believe the charging system isn't working as the battery was new. The ammeter does show charging but only when you are revving quite abit.
Couldn't pass her due to the lights not working properly etc.
So I ordered one of Hitchcocks Boyer Powerboxs as a replacement, not much of a different in price between it and the original type.
Anyone else have one? I know stinkwheel mod'd another bikes reg/rec as he also had issues with the originals. ____________________ Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65 |
| stinkwheel |
 Posted: 13:13 - 30 Jul 2015 Post subject: |
You do know some of them have direct (AC) lighting yeah? So the head and tail light only work with the engine running.
The "flash" button will work with the engine off and the tail light will come on with the sidelights with the engine off but not with the headlight.
The ammeter needle should only be just the green side of zero under normal running. Big movements either way indicate a problem. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| von1papen |
| Rogerborg |
 Rogerborg nimbA
| stinkwheel |
| von1papen |
| stinkwheel |
 Posted: 23:51 - 30 Jul 2015 Post subject: |
The headlight shouldn't affect the running of the engine in any way. At all. It's direct lighting and has its own circuit and regulator which has absolutely nothig to do with the ignition circuit. Running the headlight does not use any power from the battery or ignition.
Check your battery connections. Check your earths. Check the lighting switch.
Alternator is a piece of piss to remove if it's faulty. Three bolts for the stator. A big bolt screwed down the middle of the rotor to pop it off. It takes a fair bit more fiddling to get the stator back on and square with an even gap all the way round.
If you remove the alternator, order a new woodroffe key for the rotor because I've fucked mine every time I removed it and the hitchcocks alternator spacing tool (a bit of laminated papaer the right size to wrap round the rotor). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| von1papen |
 Posted: 13:05 - 31 Jul 2015 Post subject: |
I'd read through your page before! I await the day my oil pump kills itself
I'll get a proper look at the bike over the weekend and see what the matter is. ____________________ Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65 |
| von1papen |
 Posted: 08:24 - 03 Aug 2015 Post subject: |
Ok, so I fitted the new powerbox, she bike will start and run however there seems to be a fault with the DC circuit.
Normally when you turn the ignition on, the pilot lights and rear light would go on without the bike running right?
Nothing, no lights, no horn, nothing works.
When running everything seems ok until you hit the indicators, whereabout the rear light will flash on and off (same if the brake light is on).
I noticed that the two wires leading to the ammeter were melted/fused together.
My theory is that when the bike conked out, the original regulator was doing sod all, so when my friend revved the bike, too much power flowed through the ignition and into the ammeter, frying it and possibly other things?
I have no idea what other damage this may have done, although I can't see anything obvious. (Pilot lights and rear light work when bike is running, so bulbs are ok).
I checked the main earth and the earth at the rear mudguard and these seemed ok.
I will have to try and work through more of it tonight with the multimeter. ____________________ Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65 |
The last post was made 11 years, 68 days ago. Instead of replying here, would creating a new thread be more useful? |
