| Bubbs |
 Bubbs World Chat Champion
| J4mes |
 J4mes World Chat Champion
 Posted: 17:43 - 24 Jul 2015 Post subject: |
No offence like but you know absolutely nothing about it, even to the point where you don't even know what you need to buy yet you want to install and commission the system yourself?
Are oil burner boilers covered by building regs? As in you need to be qualified and competent to install them?  |
| Bubbs |
| J4mes |
 Posted: 17:46 - 24 Jul 2015 Post subject: |
Yes, yes I did!  |
| Sun Wukong |
 Sun Wukong World Chat Champion
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 11:07 - 25 Jul 2015 Post subject: |
Did any of your quotes specify makes and models of boiler, number and sizes of radiators, etc.?
If not, there are many online calculators (like This One) that will help you calculate the total output you need from a boiler, then select the make and model of boiler to suit.
Also, Solar Water Heating Panels are fairly easy to make yourself if they are viable for your location, and can save a decent chunk on fuel costs - even if they can only be used to pre-warm the DHW. Lots of DIY guides online.
I saved a huge amount on my own central heating system by sourcing all the parts from my local Stax Trade Centre, doing all the work myself, and just paying a small fee to get it properly tested and signed-off. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Fowlersrs |
 Fowlersrs World Chat Champion
| Robby |
 Robby Dirty Old Man
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 18:42 - 25 Jul 2015 Post subject: |
First, I'm no expert. I have been doing a shitload of research lately though as I'm currently renovating a 16th century stone cottage with a view to making it as cheap to run (and as pleasant to live in as possible).
Firstly, why oil? Expensive install and likely to get increasingly expensive to run. You've fitted a nice floor slab with insulation that's actually above code requirements if memory serves? Working on that basis you're going to need minimal flow temps, either go with Robby's suggestion of a GS/ASHP based system with a solar array for heating domestic hot water (I'd go with a PV system, you can wangle FIT payments then to offset running/install costs). Failing that, they've cut back on the handouts for biomass stoves this year but it still makes a shitload more sense than an oil system imnsho.
I'm in the process of putting together (stage one done now, multifuel burner fitted and commisioned) an integrated system, thermal store fed via solar thermal, ASHP and when needed a 16kW burner. All outputting through an underfloor system.
Like everything, it all comes down to budget and how much work you can do yourself. But - and I'm being utterly serious here - you're building a home that's going to last you a good few years. Think very carefully about running costs, the money you can recoup from various schemes for "green" heating can make a big difference. ____________________ I'm immortal. Well, so far. |
| Bubbs |
 Posted: 21:36 - 25 Jul 2015 Post subject: |
| Taught2BCautious wrote: | Did any of your quotes specify makes and models of boiler, number and sizes of radiators, etc.?
Yes, I have quotes for oil boiler, ground source heat pump, biomass etc. so have the specifics.
| Quote: | What do u call expensive quotes? Your generally paying for the experts to do it for a reason. Oil boilers are horrendously expensive, are u sure it has to be that and not LPG? |
Take it you haven't seen the cost of installing Ground source, quoted around £15k supply only! It's just too much. Biomass i've got quotes for £7.5k installed which isnt as bad. Oil I worked out, if we go second hand, is a lot cheaper. But then there's the cost of running.
| Quote: | Any reason it needs to be oil? My parents old house ran on oil, they were seriously considering spending a good chunk of cash on a wood pellet system when they came out to avoid spending silly amounts of heating. |
Wood pellet would be my 2nd choice (ground source was the first), oil is actually my last choice but i'm having muchos issues with cashflow. Looks like i'll have a £3k max budget.
| Quote: | Firstly, why oil? Expensive install and likely to get increasingly expensive to run. You've fitted a nice floor slab with insulation that's actually above code requirements if memory serves? Working on that basis you're going to need minimal flow temps, either go with Robby's suggestion of a GS/ASHP based system with a solar array for heating domestic hot water (I'd go with a PV system, you can wangle FIT payments then to offset running/install costs). Failing that, they've cut back on the handouts for biomass stoves this year but it still makes a shitload more sense than an oil system imnsho. |
Good memory!
Yes i've over specked considerably. We were originally going for a GSHP but just can't afford it. Wood pellet would be an alternative but again the budget has been rinsed. If I could find a company that would lend me money against the RHI payments then life would be great... still on that case.
I have a few leads that I need to chase up but I fear the people I speak to are inflating their costs considerably. What's the cost on a solar array these days?
Oil boiler is considered a temp solution to be honest. Just to fit the budget, get us moved in and we can figure out from there how to make use of the FIT and RHI renewable tech. Would be so much easier to be able to achieve this off the bat though.
| Quote: | I'm in the process of putting together (stage one done now, multifuel burner fitted and commisioned) an integrated system, thermal store fed via solar thermal, ASHP and when needed a 16kW burner. All outputting through an underfloor system. |
This is almost exactly what we are after (minus solar thermal). What are you spending (if you don't mind me asking).
| Quote: | Think very carefully about running costs, the money you can recoup from various schemes for "green" heating can make a big difference. |
Totally and utterly agree with you - but what do you do if you don't have the money? ____________________ Life begins at the end of your comfort zone. |
| Robby |
 Robby Dirty Old Man
| Tarmacsurfer |
 Posted: 12:39 - 26 Jul 2015 Post subject: |
£15k supply only sounds high on the sort of unit spec I'd expect you to be looking at, ground works are usually one of the most expensive segments of a GSHP install and if you know a bloke with a digger you can rent for a few days that cost can be brought down considerably (presuming you've got the space to run a slinky loop, bores are a different matter entirely). ASHP would run to around £7-£9k for a domestic as a rule. Biomass installed to HETAS standards and signed off at around the £5-£7k mark depending on the stove and how well you know the fitter. In rural areas it's a good idea to shop around the local chimney sweeps, you'll often find a bloke who's doing his ticket and looking for portfolio jobs, a discount often can be wangled.
All told, we're spending around 15-20k, that also includes a fair bit of prep (insulation, floor slab etc) and my skillset is being stretched considerably, learning a lot of the job as I go along. The 16kW stove install came in just under £3k including new cylinder (not using a thermal store yet, currently running a very well insulated Gledhill vented cylinder to replace the ancient copper thing that was there) and a lot of new pipework on the internals (private water supply, had some lead issues show up on the potability test). Also had to remove the old open coal fire and back boiler, fit a proper lintel and big hearth (slate, scored cheap and with a couple of favours).
Good question as to having the money, we're in very different positions in that the place won't be my home for a couple of years yet, so I have time to pull cash together and find the best prices. All I can really say is that I'd look to skimp elsewhere and get a decent heating system in now rather than fit fun stuff or high end finish and run a second hand bag of problems and expense that will make damn sure you have trouble pulling the savings together to get it replaced.
This is our place, it's two bungalows knocked together in the Scottish borders. We'll be extending upwards as it's currently all one floor at the minute, 60 degree pitch and a 3.4m ceiling means there's plenty of space after it has been dropped to a more normal height. ____________________ I'm immortal. Well, so far. |
| Tarmacsurfer |
 Posted: 12:45 - 26 Jul 2015 Post subject: |
This is what was installed when we bought the place. Early eighties at the newest, back boiler on it so managed DHW and also fed 5 radiators. As you can see from the midway pictures, there was no lintel in place (hence the old fall in the chimney breast) so I was left with a couple of pieces of 3x2 timber and a prayer to hold things up while the bloke I was working with shot off to find one.
It's a nice place though. Only mains connection is electricity, this makes me happy  ____________________ I'm immortal. Well, so far. |
| Fowlersrs |
| Bubbs |
| Tarmacsurfer |
 Posted: 23:15 - 26 Jul 2015 Post subject: |
Bottles are not so great for heating or hot water, fine for cooking. Another option if you're desperate in the short term, look at storage heaters? Can pick them up on the 'bay for very little. I bought a job lot of five or six for around £100 last year. They're currently stored away as I never got around to fitting the bloody things
As to the comment about renewables not being cheap, I agree totally. Up front cost isn't small. Running cost is a lot better though and more importantly the subsidies attached to them make things an awful lot more appealing. Those subsidies will disappear as the uptake rises but currently it's still a good place to put money. ____________________ I'm immortal. Well, so far. |
| Bubbs |
| Tarmacsurfer |
The last post was made 11 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
