Thinking of getting a loobman
guile
PostPosted: 14:59 - 23 Jul 2015    Post subject: Thinking of getting a loobman Reply with quote
Couple of questions:
1. The guiders drop the lube onto the sprocket but what about the links of the chain which I thought was the main part that needed lube
2. Don't the guiders flap around in the wind (i.e. against the sprocket when you're at speed)?
Can't believe nobody has come out with a better solution to such a pain in the ass job.
PostPosted: 15:50 - 23 Jul 2015    Post subject: Reply with quote
The lube goes onto the sprocket which flings it onto the chain.
Be advised that it won't work on all sprockets: the bolts on the Nazi Tractor are so far out that there's no suitable lip between the nuts and the teeth. I've just binned the delivery head, run the tube over the chain and shoved a bit of cable tie up its jap's-eye to stop it gushing out. Not ideal but better than nothing.
PostPosted: 16:04 - 23 Jul 2015    Post subject: Reply with quote
They have, there are two simple solutions.
The best is called a belt drive. But people fear change.
The other is a fully enclosed chain but people don't like how they look.
So you're stuck with an exposed drive chan that needs oiling.
PostPosted: 16:12 - 23 Jul 2015    Post subject: Reply with quote
I've used these fine a few times, including on sports bikes which have done various stunts and dirt bikes greenlaning - particularly bumpy stuff may mean resetting the position, but generally they've done fine.
It wouldn't be my ideal solution, but for the price in the biggest group offer (well, as it used to be - came out at about half price )offers excellent value - maybe you could make one cheaper yourself, but at that pricepoint doesn't seem worth the hassle.
Wonko The Sane
PostPosted: 22:32 - 23 Jul 2015    Post subject: Reply with quote
the guide has some zip ties that rub against the sprocket to transfer the lube, so it doesn't flap (that and it's held by wire)
for the price it does an ok job, I occasionally give the chain a bit of a scrub with a toothbrush dipped in oil and wipe
mine drips oil from the head when parked
RodYork
PostPosted: 12:10 - 26 Jul 2015    Post subject: Reply with quote
I have bought 6 of these over a number of years...
I have also used Scotoiler. £ for £ the loobman is better & is certainly robust enough to use off road...
Loobman have just released a newer version & im installing 2 of them shortly...GREAT VALUE for ££
https://img.youtube.com/vi/swtVmQHILDc/0.jpg
Bike trip through Europe! https://www.youtube.com/watch?v=Z2yTtFPM7Xc
Ed Case
PostPosted: 15:36 - 26 Jul 2015    Post subject: Reply with quote
I've tried these and Toturo's and for me they're more trouble than they're worth..........and they're not worth much at all.
almostthere
PostPosted: 17:59 - 26 Jul 2015    Post subject: loobman Reply with quote
better off using one of these and cheaper too https://i58.tinypic.com/2465jlt.jpg Thumbs Up
Beer, It's the reason I get up every afternoon
www.mfairco.uk
PostPosted: 19:03 - 26 Jul 2015    Post subject: Re: loobman Reply with quote
Which oilers have you tried and what didn't you like about them?
trevor saxe-coburg-gotha
PostPosted: 19:14 - 26 Jul 2015    Post subject: Reply with quote
I think they're fine but just not worth the money and effort in fitting them. As I said last time the topic came up, it takes me less than a minute to clean and oil (EP90) my bikes' chains - hence why I do it after each ride. Although the ones I use the most do have main stands, which speeds the process up significantly. I do get a certain amount of fling but it's very slight and not enough to be a problem afaic. I tend to get 30k out of chain and sprockets. Cleaning chain involves one pass w/ GT85 or diesel (latter's loads cheaper, of course), then one pass wiping w/ kitchen roll. Some blackness comes off but not much at all unless it's been raining. Then just squirt w/ oil. Pretty sure if I did more wet weather riding that 30k figure would come down, mind you. Still, I honestly don't get why it's regarded as some sort of onerous task or a pita.
temeluchus
PostPosted: 20:07 - 26 Jul 2015    Post subject: Reply with quote
I've used loobman on several bikes. Works just fine, but I find it is much easier to have the hose drip onto the rollers just before the sprocket and not use the feed head. Seems to oil everything just as well without the risk of things getting torn off.
far less time and effort than scrubbing chains.
Alex A
PostPosted: 20:55 - 26 Jul 2015    Post subject: Reply with quote
I've bought several bikes with automatic chain lubricating systems, including loobman and scottoiler. In my experience, all they really seem to do is fail and/or make a mess. O-ring and X-ring chains retain grease internally. For external lubrication, an occasional, light application of non-fling chain lube is (IME) entirely adequate (and a lot less messy).
ferrisio
PostPosted: 21:18 - 26 Jul 2015    Post subject: Reply with quote
MrGs1 wrote:
I've just read an interesting thread about the AB loobman. I am still unsure of what oiler to buy they all seem to get mixed reviews.
I had an AB version like in that thread and found most of the same things. The reservoir leaked, the folding delivery head thingy didn't close well, and I never got it fitted satisfactorily.
To be fair, I never contacted Loobman to sort it out as I'd spent ages messing about with it and the reservoir had dumped its oil again - so they may be better now, but I didn't have a great experience with it.
BMW R1100R
The last post was made 11 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 87.13 Kb
