| thehairysmite... |
 thehairysmite... Borekit Bruiser
| Aff |
 Aff World Chat Champion
| baldy |
 baldy World Chat Champion
| thehairysmite... |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:21 - 27 Jul 2015 Post subject: |
I'd hazard a guess that it's been shipped with no acid in the battery. My bike-in-a-box came with a dry battery and the acid in a separate bottle.
Seat or panels off, find the battery.
If it's a sealed gel battery, fair enough, stick it on a charger.
If it's a wet cell battery like this...
https://www.countybattery.co.uk/uploads/product/zoom_12N7-4A_12V_7Ah_Yuasa_Battery_Acid_Sold_Separately.jpg
... then there should be acid visibly sloshing around between the level markers in every cell. That picture is of a dry battery. That's what you don't want it to look like.
If it's dry, you'll need acid. You can chase up the stealer that sold it to you, buy on eBay or pop down to the local motor factor and see if they'll flog you some. ____________________ Biking is 1/20th as dangerous as horse riding.
| thehairysmite... |
| serlant |
 serlant Brolly Dolly
| thehairysmite... |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 22:00 - 27 Jul 2015 Post subject: |
We've got a 2009 Pulsar here, very simple bike and so far a reliable little runabout.
Remove the side panels by moderately pulling at them.
so the pins come out of the rubber grommets highlighted in yellow.
The battery is behind the RH one and easy to access.
You can remove both the 12mm headed seat bolts too if you want
(red arrow)
Under the seat is the main fuse, starter solenoid, CDI box, flasher relay and rectumfrier
Your problem may well be just the stated flat/uncharged or dry battery
and probably is.
It should start via the kick starter though as its an AC CDI bike, but ours had a vac
fuel tap which can be a PITA at the relatively slow kick over speed
and I swapped it out for a manual one.
Once you start to clock up miles don't forget to keep an eye on the cam chain adjustment
(adjuster at white arrow) we got ours cheap as it had worked loose and caused the chain to jump
and bend the valves.
Checking oil:
There is a sight glass on the front lower right of the engine you know
On the mainstand on level ground and at rest, oil should be 3/4 of the way up the window.
If you use the dip stick, don't screw it in to get the level, just push it down until it stops
then when you're happy its ok, screw it in
Choke Lever:
left for on and right for off
dont over do it and don't keep winding the throttle when starting
https://oi58.tinypic.com/2q866nm.jpg ____________________ bikers smell of wee |
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:22 - 27 Jul 2015 Post subject: |
The bike will (probably) kick and run without the battery being functional.
As it didn't show any signs of life initially on the electric starter, I'd check the electrolyte levels in battery anyway, to rule it out.
Even if looks good then I'd charge it up anyway, and I don't mean riding it around a bit. If it came fully discharged - which is bad news - then it'll need many hours on a charger to fully charge it. Skimp on that now and you may find that it'll never hold a full charge and you'll be doing a lot of kick-starting. ____________________ Biking is 1/20th as dangerous as horse riding.
| thehairysmite... |
| thehairysmite... |
| andys675 |
 andys675 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:32 - 01 Aug 2015 Post subject: |
Good stuff. Was it just not charged then? I'd keep it on a charger for a while to try and get it up to peak capacity, especially if you're not riding it regularly. ____________________ Biking is 1/20th as dangerous as horse riding.
| Vincent |
 Vincent Banned
The last post was made 11 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
