| Azmodeus |
 Azmodeus Scooby Slapper
 Posted: 14:44 - 03 Feb 2005 Post subject: Measuring a Bolt? |
This is going to sound stupid, but how do I measure a bolt?
I ordered a pair from a peugeot garage to fix my exhaust cover on. The woman knew exactly what I wanted, and said she would send them off. I got them about 2 weeks later ( ) and they are the wrong ones.
So I phone them up, and ask for the right ones. No problem, send them right over. Another fortnight, no word. Phone them again, and she says that she is looking at them right now, and they will be sent asap. Another fortnight, another phonecall, and I get "sorry sir, we never recieved the order".
So I am now trying to find the right size myself. They only need to be about 1mm "narrower" than the ones I have. Length doesn't matter because I can cut them down.
Suggestions? |
| Frost |
 Frost World Chat Champion
| ZRX61 |
 ZRX61 Victor Meldrew
| Azmodeus |
| Scotsman37 |
 Scotsman37 World Chat Champion
| alains |
 alains World Chat Champion
| G |
 G The Voice of Reason
| Git |
 Git Brolly Dolly
 Posted: 12:15 - 05 Feb 2005 Post subject: |
Go buy a thread guage tool, this will tell you the pitch the bolt has, alternatively goto a specialist nut and bolt place hand them the bolt and tell them you want the next size down or whatever it is you require.
I use ahc in camberley for all my nuts and bolts, they never fail to let me down  |
| alains |
| Azmodeus |
 Posted: 12:41 - 05 Feb 2005 Post subject: |
Just FYI - This is picture of one of the bolts.
Needs to be identicle to this one, but 1mm or so narrower
2 of them  |
| G |
| alains |
| Azmodeus |
 Posted: 13:04 - 05 Feb 2005 Post subject: |
Better yet, I'll show you
Sorry for the crap quality, but its only a cheap camera.
I have a metal plate which fits over the exhaust, and these 2 bolts/screws fix it on. |
| Git |
 Git Brolly Dolly
| alains |
| Azmodeus |
 Posted: 13:25 - 05 Feb 2005 Post subject: |
Only drill-bits I have are for plaster and wood. Plus I dont fancy mangling my bike for the sake of a cover.
And its the exhaust, so I cant get inside to screw on a nut.
Actually, thinking about it, would normal bolts be able to withstand the heat from the exhaust?
By the way - https://www.b3ta.com/board/4232187 |
| Git |
 Git Brolly Dolly
| Scotsman37 |
 Posted: 13:40 - 05 Feb 2005 Post subject: |
Ones made of steel even stainless steel to avoid rusting is much better. If you can find an appropriate bolt with the correct length., but if you can't then cut it to length but you may need to file down the start of the thread just a tiny bit to get a smooth start to screwing it through the nut. Also, the bolt has to be of the correct diameter as to avoid movement of the exhaust.
Just remember to buy with it the matching nut for the bolt with a washer as that will help to keep a good tight fit.
You may find that your local iron monger can do the above work for you as mines does free of charge!  |
| Azmodeus |
| Scotsman37 |
 Posted: 15:09 - 05 Feb 2005 Post subject: |
You can do it that way if you want as it will remove any burrs when undoing the nut, except I knew this person that was once an engineering instructor and he had the right tool for the right job which was very handy for me when I needed anything done !  |
| catgate |
 catgate Two Stroke Sniffer
 Posted: 14:54 - 06 Feb 2005 Post subject: |
I feel I must poke my nose in here.
| Quote: | well guys the size in metric are :
4x60 , 5x80 , 6x100 , 7x100 , 8x125 , 10x150 , 12x175
first number is the diameter , second number size of the thread | .....the numbers do indeed resemble something approaching reality but they are really :-
M4 x 0.60mm, M5 x 0.80mm, M6 x 1.00mm, M7 x 1.00mm, M8 x 1.25mm, M10 x 150mm, and M12 x 1.175mm
The M figure denoting a metric bolt (or nut) of the quoted number of millimeters in diameter and the second number quoted is the actual pitch of the thread (i.e. the distance apart of the individual threads (as quoted above). The numbers in this example are for the range known as Metric coarse. There is another fairly commonly used range known, for obvious reasons, as Metric fine, and there is yet another less frequently used range of extra fine sizes. The size of the hexagon heaad is often a guide to the diameter of the bolt (or nut) but is not by any means absolute, neither is the socket size a guide in capheads etc. ____________________ "Always remember you're unique, just like everyone else." |
| ZRX61 |
 Posted: 16:40 - 06 Feb 2005 Post subject: |
Just buy a couple of Stainless self tappers from the hardware store, sorted.  |
The last post was made 21 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
