Vauxhall Vivaro problem! please help!!!
robs321
PostPosted: 20:07 - 28 Jul 2015    Post subject: Vauxhall Vivaro problem! please help!!! Reply with quote
My 07 Vivaro is doing my conkers in.
Its been running fine for the last 80k miles until last week. It had a total loss of power and the glow plug and service light came on.
My mate stuck it on his machine and it pointed to the turbo solenoid. £46 later it ran fine for about a day, then same thing.
The thing is, if you disconnect the solenoid, link the 2 vacuum pipes, it runs brilliant, but I have the warning lights back on the dash.
Any Vauxahall/Renault techy types who can help?
cheers in advance.
Shaft
PostPosted: 21:06 - 28 Jul 2015    Post subject: Reply with quote
Factory solenoid or pattern part?
I would suspect a faulty replacement part, which is much more likely if it's not genuine.
robs321
PostPosted: 21:44 - 28 Jul 2015    Post subject: Reply with quote
Genuine!
RhynoCZ
PostPosted: 21:50 - 28 Jul 2015    Post subject: Reply with quote
https://i.imgur.com/4pgXXfv.jpg?1
PostPosted: 22:11 - 28 Jul 2015    Post subject: Reply with quote
My Astra had horrible issues with the vacuum stuff. So much so we bodged vacuum similar to how you have and covered the stupid light.
Just_James
PostPosted: 22:21 - 28 Jul 2015    Post subject: Reply with quote
Not had experience with the Vivaro specifically but I'd check the easiest and cheapest things first.
Check vac pipes for splits / leaks.
Check EGR valve, could try just blanking it off for now, some you can blank off by just rotating it.
Clean MAF sensor.
If still no different I'd suspect your replacement solenoid.
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
RhynoCZ
PostPosted: 22:52 - 28 Jul 2015    Post subject: Reply with quote
My mate also had problems with his Vectra 2.0 Ecotec engine. The thing is, there are those very thin black plastic vacuum pipes and lines, that has to be in perfect condition, or the engine's gonna start coughing and acting up. Even a small leak can cause big issues. Thumbs Down
But as James says, I'd check the solenoid. I mean, that's the last part you touched before it got fecked up. Smile
robs321
PostPosted: 16:13 - 29 Jul 2015    Post subject: Reply with quote
Hi, thanks for the replies, Ive just ordered a new set of hoses to the solenoid and will try that next.
Dont really want to go down the blanking off the light route. Not really helpful when a proper fault shows up and you carry on driving?
cheers!
petalbriefs
PostPosted: 16:40 - 29 Jul 2015    Post subject: Reply with quote
I work for Vauxhall HQ in Luton, let me know how you get on once you fit those hoses.
I sit with technical guys and know the techie guys in our dealer assistance team in Newcastle, we have a workshop on site and I know a few people in dealers too.
All that said, I'm not promising a solution, but will definitely ask around and help if I can. Thumbs Up
PS
Did he retrieve a specific fault code when he plugged it in?
P0***?
Proud owner of an R6 Smile + ZXR400
Honda CBR 125 R - Stolen
robs321
PostPosted: 16:53 - 29 Jul 2015    Post subject: Reply with quote
PS
P0***?
Thanks for that! Thumbs Up there was a specific code but I cant remember it off hand, ill borrow his scanner weekend and re-read it. New pipes wont be here for 5 days!
petalbriefs
PostPosted: 17:11 - 29 Jul 2015    Post subject: Reply with quote
Cool, well if you get the code and let me know, I will have a look through the technical documents we have, see if there is anything common and will ask the guys I know.
Hopefully we can help sort it Very Happy Thumbs Up
The last post was made 11 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 70.28 Kb
