| B0ndy |
 B0ndy Spanner Monkey
| monkeybiker |
 monkeybiker World Chat Champion
 Posted: 16:41 - 29 Jul 2015 Post subject: |
Chain tensioner should be removed first.
You have to loosen each bolt a little at a time so it comes off evenly.
This pic is for tightening so to loosen start with no:10 and work back. Loosen each bolt little by little.
Your haynes manual should have a description and picture.
Once you have cams off take out one bucket at a time and measure the shim make a note of it and then put it back in it's place so you don't mix them up.
Take your time
When you put it all back together make sure the chain timing is correct and re-check valve clearance. Don't start the bike until you are 100% happy all is correct. |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 18:28 - 29 Jul 2015 Post subject: |
Seems odd that Haynes warns against it. What is so special about a cb400?
Shim under bucket is not exactly limited in its use across engines.
So does the Haynes manual actually spell out the procedure?
Also, can you download the official Honda service manual from anywhere? Sometimes its good to have two explanations of the same thing......sometimes its more confusing  |
| B0ndy |
| A100man |
 A100man World Chat Champion
| FlightRisk |
 FlightRisk Spanner Monkey
| Fizzer Thou |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 13:15 - 30 Jul 2015 Post subject: |
My
As well as using a piece of wire to prevent your cam chain disappearing into the guts, stuff every orifice with non-shedding cloth. Fishing a nut from the guts is not nearly as easy as preventing it getting there in the first place.  |
| Fizzer Thou |
The last post was made 10 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
