Kmx indicators not working
Dedge1
PostPosted: 23:30 - 29 Jul 2015    Post subject: Kmx indicators not working Reply with quote
Hi all. Could someone help me out here!! I have a Kmx 125 all the electrics work as they should apart from the indicators I've tried alsort even checked there no breakage or dodgy wires in the loom. There is just no power going to the wire where the indicators plug into the is power to the flasher unit but after that just nothing even the turn signal on the dash light doesn't come on. Any ideas would be great. Thank you 👍👍👍👍
Taught2BCauti...
PostPosted: 08:40 - 30 Jul 2015    Post subject: Reply with quote
Do your indicators have their own separate fuse, or do they share a fuse with another circuit, like the horn for example?
If you have +12v on both sides of the fuse, but no +12v at the flasher can, there must be a break in the wire or a dodgy connector block.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Raffles
PostPosted: 10:25 - 30 Jul 2015    Post subject: Reply with quote
Assuming you know the flasher unit to be okay, you need to check the wiring and any associated connectors between the flasher unit and the indicator switch.
The indicator switch itself should also be considered a suspect.
The last post was made 10 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.57 - MySQL Queries: 13 - Page Size: 35.6 Kb
