| Wighty |
 Wighty Two Stroke Sniffer
 Posted: 13:15 - 27 Jul 2015 Post subject: 2005 Varadero 125 Electrics Cutting out. |
Gonna have to give a timeline of events here:
- Bike first cuts out when doing a bit of pre-CBT training, Battery gets charged, everything seems fine.
- Complete CBT, go for a short ride the next day (approx 20 minutes), park it up, about 1-2 hours later it doesn't start up again.
- Gets taken for an electrical diagnostic test, get told the regulator is f**ked.
- New (OEM) Regulator fitted. Everything seems fine; go for another ride (30-45 minutes) and it goes again. Get told the battery may be goosed too.
- New battery. Once again everything seems fine, Passes MOT and I rode it for a few hours on Saturday, I get it home, test the voltages and it's all good.
- Go to work today, has a little trouble firing up but it does after 2-3 attempts. 30 minutes later, stopped at a junction and bam, it cuts out again.
- I proceed to curl up in to a ball and cry for a few minutes. (May or may not have actually happened)
Worth Noting:
- When the bike is at tick-over (no throttle), the battery is being drained rather quickly.
- Charge does get in to the battery (approx 12.5-13.5 V) when revs are applied ____________________ Big twat on a 2005 Honda Varadero 125. |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Wighty |
| samv |
 samv Derestricted Danger
| Wighty |
| samv |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 09:16 - 30 Jul 2015 Post subject: |
+1 for checking the stator windings.
Disconnect the reg/rec and lable the 3 yellow wires coming from the stator as A, B, and C.
Check the resistance of each pair - A and B, A and C, and B and C - they should be roughly the same.
Also check the resistance between each individual wire and earth - should be infinity. Check you have a good earth on the reg/rec and the frame, engine and battery negative.
Also check the condition of the wires as they leave the generator housing, and the condition of both parts of the reg/rec connector block.
Sometimes when the reg/rec fails, it will allow the battery to drain back through the stator windings, and you can feel them getting warm. In some cases, this can cause the soldered joints to melt, or the windings to burn-out.
A faulty reg/rec can damage the stator and the battery, a faulty stator or battery can damage the reg/rec - it's a vicious circle. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Wighty |
| bikenut |
 bikenut World Chat Champion
| Taught2BCauti... |
 Posted: 15:32 - 31 Jul 2015 Post subject: |
The last post was made 11 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
