| someguy |
 someguy Borekit Bruiser
 Posted: 19:55 - 30 Jul 2015 Post subject: Why won't my YBR125 shift? |
Yo BCF,
On the way into work this morning my YBR125 stopped shifting down into first. I had to pull away in second gear for the rest of the journey.
On the way home, I tried to see whether it was me or the bike, but it seems the problem is getting worse.
The lever "feels" different now too. Kind of "loose".
So now, no matter how I shift, I can't get it to go down a gear easily. It will shift up (sometimes), but it's very difficult to shift down, especially in the lower gears - which means I'm having to pull away in third gear - not what you want in London traffic.
5th -> 4th is ok, 4th -> 3rd is ok (sometimes), but 3rd->2nd and 2nd->1st are nearly impossible.
If I get off the bike and shift it by hand, it will eventually shift down with a bit of wiggling, but there's no way I can manipulate it like that with my foot on the move.
What's going on?
Where do I start trying to fix it?!
Edit: I've had this bike for about 5 months, it's been fine up until now. |
| Brick_Top |
 Brick_Top Spanner Monkey
| arry |
 arry Super Spammer
| someguy |
| Brick_Top |
| someguy |
 Posted: 20:51 - 30 Jul 2015 Post subject: |
| Brick_Top wrote: | If that was the case normally your bike would creep forwards with the clutch in, at standstill in gear.
There's one on the lever, often another by the clutch arm. |
That doesn't happen - if I pull the clutch in, the bike just sits at a standstill without any creeping. I've just been out for a little ride... I think I know what the problem is.
I think there's a spring that returns the gear lever to the "neutral" position, which is broken or loose or weak.
I can ride around it by doing the following:
Shifting up:
Bike in gear, rolling along, clutch engaged
Apply slight downward pressure to the lever to return it to the "neutral" position whilst clutch is engaged
Clutch in, shift up, clutch out
Shifting down:
Apply slight upward pressure to the lever to return it to the "neutral" position whilst clutch is engaged
Clutch in, shift down, clutch out
I guess that explains why it's easier to shift up - because gravity does the "downward pressure" for me sometimes. The opposite also makes sense - because I'm generally "shifting down after shifting down" when traffic slows (say from 4th, then to 3rd, then to 2nd), the lever stays "stuck" down after the first downshift, and needs a little gentle upward pressure to return it to its normal position before the subsequent downshift.
Does that sound right? If so, how can I get at this spring to check it/change it? |
| Nobby the Bastard |
| someguy |
| Nobby the Bastard |
| someguy |
| Brick_Top |
| Nobby the Bastard |
| bikenut |
 bikenut World Chat Champion
| Vincent |
 Vincent Banned
The last post was made 11 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
