| Gazz |
 Gazz World Chat Champion
| Itchy |
 Itchy Super Spammer
| kramdra |
 kramdra World Chat Champion
 Posted: 21:45 - 30 Jul 2015 Post subject: |
Most are overpriced bollocks, there is no advantage of known brands, their mounting systems are rubbish and only rated 3kg...
The best ones are about 25 quid on ebay (marketed as 45-52-65 liters, all same size), in my opinion, and I've had a few (a Honda branded box, givi, and two cheapies).
The recessed handle area on most, especially branded ones, does seriously impede the storage space and is quite annoying.
Most are easily removed (single bolt locks it on) but I would recommend bolting through the box and having a removable rack, it will be much more secure.
Yes you can buy the spongy bit, but for a branded bx it will cost more than a whole cheap box. Instead buy a thick wedge of neoprene foam from ebay.
The givi arms linked above are also shite. A rentec rack is better
| bamt |
 bamt World Chat Champion
| sickpup |
 sickpup Old Timer
| MCN |
 MCN Super Spammer
 Posted: 23:23 - 30 Jul 2015 Post subject: |
I mounted a Givi system on an 09 ER6F.
Bastart of a job as the bike has almost to be disembowelled to fit the mounting 'arms' to the frame.
A lot of the holes are awkward to line up and just a bit poor as far a 'Kits' go.
Instructions good not so. Clear not very photographs/drawings.
I guess if you fit them all the time then you get better and know the pitfalls but not an Easy Job unless you have time and patience.
I hoofed my tool box up the end of the garage twice.  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:50 - 31 Jul 2015 Post subject: |
F800/700/650GS has mounts for a top box built right into it. You re-purpose the two rear bolts of the grab handles and remove a couple of plastic bungs to reveal the other two. Solid as a rock, weight is straight down onto the subframe rather than perched behind it on a lever. I've had 10kg+ of anchor chain in there, bags of cat litter, beer runs, all sorts, never a hint of a problem.
This isn't meant to be helpful, I'm just bragging.  ____________________ Biking is 1/20th as dangerous as horse riding.
| MCN |
 MCN Super Spammer
| Mudshark |
 Mudshark Nearly there...
| GaryJM |
 GaryJM Borekit Bruiser
| Gazz |
 Posted: 17:51 - 31 Jul 2015 Post subject: |
Just been onto the J and S website and they only seem to have 3 available.
https://www.jsaccessories.co.uk/luggage/top-boxes
Do you think the Dr. Bike one would be the best option to go for then? It is the 44litre one.
It will probably end up on my Honda Deauville first off. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:15 - 31 Jul 2015 Post subject: |
You might get 2 lids in that, if they're small shelled and there's nothing else in it. I went to 58 litres and it just barely fits a flip and a full face. ____________________ Biking is 1/20th as dangerous as horse riding.
| kramdra |
| Rogerborg |
 Rogerborg nimbA
| Dave_R |
 Dave_R Nova Slayer
 Posted: 10:17 - 01 Aug 2015 Post subject: |
| MCN wrote: | I mounted a Givi system on an 09 ER6F.
I had no trouble fitting Givi arms on my 09 ER6n which has the same rear end. I don't know what you did that I didn't, because I wouldn't call a bike with the grab rails and the rear seat removed "disembowelled".
For future reference; use a bit of mechanical sense and keep in mind this is an aftermarket part that's hand made in Italy. The bolt holes will be very difficult to align if you tighten the bolts too soon, leave everything loose and floppy until everything, including the plate has been attached.
On a related note, I've been very happy with my Givi V47 monokey box; it just about fits two lids, it's rated to 10kg and I've been loading 16kg in it daily for a few months. |
| Snod Blatter |
 Snod Blatter Crazy Courier
| sickpup |
 sickpup Old Timer
| Itchy |
 Itchy Super Spammer
| Pol Anorl |
 Pol Anorl Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 14:08 - 01 Aug 2015 Post subject: |
I have this topbox...
Its good and lasted me but..
the plastic bits to stop the lid opening all the way snap easily... like first use.
The metal pins that hold the lid to the bottom will fall out and have to be replaced with long nails.
it will evetually get weak and be a bastard to shut without the key.
But ive had 30kg+ in mine and had no problems with it and 2 helmets with a few tools. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| kramdra |
 Posted: 00:12 - 02 Aug 2015 Post subject: |
No, Givi arms use the pillion peg mount as a pivot but all of the load is through the 4x M8 grab handle mounts. However the givi arms are also weak as piss, bend easily and cost 2x more than a replacement used subframe. Replacement arms are not easy to find.
"potentially adversely affect the handling" = wheelies. My bike prefers the extra weight of pillion and full box when riding faster. Acceleration is adversely affected, but rear is less twitchy, front more planted. |
| sickpup |
 sickpup Old Timer
 Posted: 09:01 - 02 Aug 2015 Post subject: |
| kramdra wrote: | No, Givi arms use the pillion peg mount as a pivot but all of the load is through the 4x M8 grab handle mounts. |
No. The weight may not be spread evenly or even in the same plane but it is spread.
| kramdra wrote: | However the givi arms are also weak as piss, bend easily |
No they don't unless they are old and have internal corrosion. Regardless they are supposed to be weaker than the subframe to act as a sacrificial part.
| kramdra wrote: | and cost 2x more than a replacement used subframe. |
Two assumptions.
1. That the subframe can be replaced ie is bolt on.
2. Assumes you can find a used one.
| kramdra wrote: | Replacement arms are not easy to find. |
Yes they are. Try either Ebay or messaging Givi direct has always worked for me, surprisingly cheap as well Givi contact page.
| kramdra wrote: | "potentially adversely affect the handling" = wheelies. My bike prefers the extra weight of pillion and full box when riding faster. Acceleration is adversely affected, but rear is less twitchy, front more planted. |
No, potentially adversely affect the handling by raising the centre of gravity and placing mass behind the rear wheel axle as well as placing a box in the air stream creating odd air vortices and turbulence around the box.
The front isn't more planted, you have changed the front/rear mass ditribution towards the rear unless you compensate by leaning forward.
Don't quit the day job.  |
| MCN |
 MCN Super Spammer
| Dave_R |
 Dave_R Nova Slayer
| kramdra |
 Posted: 17:05 - 02 Aug 2015 Post subject: |
| sickpup wrote: | | kramdra wrote: | No, Givi arms use the pillion peg mount as a pivot but all of the load is through the 4x M8 grab handle mounts. |
No. The weight may not be spread evenly or even in the same plane but it is spread. |
The givi arms convert the small lever force to a downwards force acting on the same place. Its irrelevant, even with a large multiplier the load is still within ratings.
| sickpup wrote: | | kramdra wrote: | and cost 2x more than a replacement used subframe. |
Two assumptions.
2. Assumes you can find a used one. |
This does depend on the bike.. most bikes worth owning have a replaceable steel or aluminium tube subframe, which are very strong. Steel frame bikes they are welded on.
As subframes rarely ever break therefore there are a lot of them available and cheap. Hit a tree sideways or rear ended by car, that will break one. Topbox will not.
https://www.ebay.co.uk/itm/271809048620
https://www.ebay.co.uk/sch/i.html?_from=R40&_&_nkw=cbr600+subframe&_sacat=0
Alu Diecast subframes on more recent bikes are cheap to make, but much more likely to crack, lower ratings.
| sickpup wrote: | | kramdra wrote: | Replacement arms are not easy to find. |
Yes they are. Try either Ebay or messaging Givi direct has always worked for me, surprisingly cheap as well Givi contact page. |
Years ago there were none available when I was looking, it was considered a discontinued part. Yes they are now available if paying 90 quid, which is twice what I paid last time.. https://www.ebay.co.uk/itm/191623654268
| sickpup wrote: | | kramdra wrote: | "potentially adversely affect the handling" = wheelies. My bike prefers the extra weight of pillion and full box when riding faster. Acceleration is adversely affected, but rear is less twitchy, front more planted. |
Under braking and leaning in, the front has much more confidence with weight on the back. |
The last post was made 11 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
