How would you cut this down?
PostPosted: 22:38 - 30 Jul 2015    Post subject: How would you cut this down? Reply with quote
https://ecx.images-amazon.com/images/I/41aHzh1feXL._SX300_.jpg
This is a seat post clamp it is slightly too long.
The side with the washer is threaded like a bolt. My plan was to cut down the other side with a hack saw then run a tap down the thread to resurrect it. Any better ideas?
PostPosted: 22:41 - 30 Jul 2015    Post subject: Reply with quote
Spacer washer under each head.
bugeye_bob
PostPosted: 23:38 - 30 Jul 2015    Post subject: Reply with quote
how much too big is it ?
PostPosted: 23:40 - 30 Jul 2015    Post subject: Reply with quote
I'd clamp it in a vice and file the female end with a hand file.
bugeye_bob
PostPosted: 00:10 - 31 Jul 2015    Post subject: Reply with quote
Depends if the threads bottom out in the nut / female part.
PostPosted: 00:22 - 31 Jul 2015    Post subject: Reply with quote
That's how they fit tightly against one another. In the unlikely event they didn't, I'd file both sides.
mentalboy
PostPosted: 00:55 - 31 Jul 2015    Post subject: Reply with quote
Whereas I'm far less subtle than your esteemed self and would probably employ the same method with a grinding wheel Mr. Green
PostPosted: 06:54 - 31 Jul 2015    Post subject: Reply with quote
Filing the female end would work but once the bolt end hits the bottom of the hole you'll need to cut thread down. When the thread engagement gets below one diameter you're compromising the connection.
PostPosted: 09:15 - 31 Jul 2015    Post subject: Reply with quote
Washers were my initial thought but it has a lug on one side which stops the use of the washers on that side. Stacking them up on the other would affect the aesthetics. Wink
https://img.photobucket.com/albums/v295/chris-red/32437216-25DE-46A2-B899-86568A11CCB7_zpsljum6hcd.jpg
Thats how much I have to play with, I can see the thread goes up to the the shoulder I guess I'll try it gradually with the file Thumbs Up
And as to how much It needs cutting down, I do not know, but it doesn't clamp the tube hard enough, I'll start with about 3/4mm and go from there.
PostPosted: 09:31 - 31 Jul 2015    Post subject: Reply with quote
A spring washer might be narrow enough, or you could grind down a normal washer?
PostPosted: 12:20 - 31 Jul 2015    Post subject: Reply with quote
It'll ruin the aerodynamics Wink
bugeye_bob
PostPosted: 12:37 - 31 Jul 2015    Post subject: Reply with quote
can the hinge be opened up a little to make it fit
PostPosted: 13:09 - 31 Jul 2015    Post subject: Reply with quote
It's a clamp. If I open it up and then tighten it it'll be in the same position.
bugeye_bob
PostPosted: 13:16 - 31 Jul 2015    Post subject: Reply with quote
if it is that critical why not buy the correct size.
PostPosted: 13:30 - 31 Jul 2015    Post subject: Reply with quote
Do you understand what it is used for?
The bolt tightens on a clamp, the clamp clamps onto a seat post. If I widen the clamp when I tighten the bolt it will still only tighten the clamp to the same ammount, not enough to hold the post. Filling down the female side will allow it to clamp tighter.
No point buying another with I can modify this one, it'll be quicker than waiting for another to arrive and won't cost anything.
pompousporcup...
PostPosted: 15:22 - 31 Jul 2015    Post subject: Reply with quote
cut the female end and then if needed run tap through it if the thread is deaded. Providing the female part open on the other
The last post was made 11 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 98.61 Kb
