| supZ |
 supZ World Chat Champion
 Posted: 12:02 - 27 Jul 2015 Post subject: Worrying tankslappers on the blade |
I'm well under way trying to sort this out but I thought I'd post it here to see if any of you guys have any ideas I haven't thought of.
The back story is the other week I suddenly got a major tankslap on as I was overtaking a couple of cars. Not hard on the throttle, probably around 50-60mph.
I chalked it down to dodgy road surface (looks pretty err undulating) and didn't think much of it.
3 days later on the same road but a few miles further down it I have the same experience.
I then had it again the following day and this one shook me up. I've had front and rear tyres slip out on track, and the odd headshake hitting catseyes with the front as it comes back down after some hard throttle but this was completely different. I wasn't pushing it, I wasn't doing anything out of the ordinary but yet I was currently in the middle of the road, handlebars swinging wildly, with cars around me convinced I was about to hit the floor.
Thankfully I got control back but at that point I thought something has to be wrong.
Bike's a 03 954 which I've had for around 4-5 years.
# Headrace bearings were replaced 2 services ago and were re-checked and are fine
# Wheel bearings seem fine, freely spins
# Tyre pressure/balance was fine (around 34psi)
# Suspension serviced - forks and shock by MCT, new oil, springs, setup all done
Even after the suspenders gone re-done the bike still doesn't feel right. Feels like there's not enough weight on the front so any bump appears to unsettle it. Even with next to no throttle at low speed the slightest bumps seem to give it a problem. Should point out that just a normal bump in the road is fine but many bumps seem to magnify the issue, it's almost like it can't recover in time and it gets worse every time (like when you're crossing painted lines)
Had another headshake again after re-fitting the forks and that so at this point I've lost all confidence in the bike.
The only thing that could be a factor is a few days before I started getting this I got a new front tyre. I've mainly used BT023s on the blade but the shop didn't have one so I got a T30 instead which is just meant to be bridgestones newer version of their sport touring tyre.
I began wondering if there was something wrong with the tyre.
To that end, to try to eliminate any possibility I've bought another 23 and had that fitted yesterday. I haven't ridden today to see if that's made any difference so that's still to be determined.
Now the road where I've mainly these issues (A30 - between bagshot/sunningdale) has a middle turning lane with hatchings on. It's almost like the front wheel is bumping over these hatchings and getting all out of alignment. The only issue is, I've been riding this road virtually every time I've been out on the bike for the last 6+ years and never had any issues overtaking.
It's happened in 5 different places now, and other than the 1st time, there's been no road works where they'd repaint the lines thick or something (clutching at straws here)
I don't think it's JUST this road, it's just I use this road to go to and from work and due to the issue I've not ridden it anywhere else
The worst thing is, it's killed my confidence on the bike. I can't overtake any more as I'm scared to death the moment I do the bike will spit me off!
Any thoughts?
TL;DR: Bike's trying to throw me off! Why?! ____________________ CBR954RR - Daily toy
CBR600RR - Trackbike |
| baldy |
 baldy World Chat Champion
| UrbanRacer |
 UrbanRacer World Chat Champion
| JoeDougieDoug... |
 JoeDougieDoug... World Chat Champion
 Posted: 12:28 - 27 Jul 2015 Post subject: |
So it's just happening on this stretch of road? It doesn't appear to happen anywhere else on any of your journeys?  ____________________ CBT Passed - 22 / 10 / 11 >> Theory Passed - 16 / 02 / 2012 >> Mod 1 Passed - 07 / 03 / 2012 >> Mod 2 Passed - 18 / 05 / 2012. |
| robertw95 |
 robertw95 Trackday Trickster
| samv |
 samv Derestricted Danger
 - Super Spammer
| chris-red |
| MarJay |
 MarJay But it's British!
 Posted: 20:13 - 27 Jul 2015 Post subject: |
Stop looking at the front end.
Tankslappers propogate from the rear of the bike not the front. The slapping is just the result of the back-end squirming about.
So check all the sort of stuff you've already checked but at the back end of the bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bikeless |
 Bikeless World Chat Champion
| supZ |
 Posted: 22:42 - 27 Jul 2015 Post subject: |
Thanks for the replies all.. I'll try to answer all the questions.
| baldy wrote: | Have you checked the rear shock components? There could be a problem or the geometry could have changed. |
Rear shock's just been serviced by MCT and bolted back on by me. Prior to that it's never been changed or off in the time I've owned it.
| Liam_ wrote: | Have you had this bike for a while and its now suddenly started doing it? any changes to suspension setup? |
Had it for years, covered 000s of miles on it and yes, just started. My suspensions just been serviced and setup by MCT but prior to that no changes were made and the problems started before the service (I got it done to try to resolve the issue)
| JoeDougieDouglas wrote: | So it's just happening on this stretch of road? It doesn't appear to happen anywhere else on any of your journeys?  |
As it's been trying to throw me off I've not wanted to go anywhere but work on it. I did ride to training last week though and took it very easy. It just 'feels wrong' on any road.
| robertw95 wrote: | Are the forks sitting flush with top yoke? |
Pretty much yes, re-fitted myself after the fork service.
| samv wrote: | my thought would be that the geometry changes somehow. maybe after servicing the suspension |
I got the suspension serviced to try to resolve the issue. Wasn't touched before that
| chris-red wrote: | Give MCT a call, I've always found Darren more than willing to have a chat about stuff like that. |
Yeh been talking to Darren and Tom at length about it. He was horrified when I told him that I barely felt any improvement afterwards as he previously told me it should be a 'night and day' difference with the changes they made (new springs, oil, shock service etc..)
| stinkwheel wrote: | Stop looking at the front end.
So check all the sort of stuff you've already checked but at the back end of the bike. |
It's a good call and I agree, although nothing has changed at the rear for a good while so it wasn't my 1st thing to look at.
MCT have suggested popping over and they'll help me go through a full setup but they're like 150 miles away so it's not like I can just pop over on a whim.
Anyone know any decent suspension places in the SE (berkshire/surrey way)?
I'm loathed to put a steering damper on. As Tom says, a well setup bike shouldn't need one and I've certainly not needed one for 4+ years on it so why now? It's definitely a last resort.
Thanks for the replies guys. Hopefully I'll get out on it tomorrow and see if the tyres made a difference.. if not I'll start looking in other places ____________________ CBR954RR - Daily toy
| supZ |
 Posted: 23:00 - 27 Jul 2015 Post subject: |
I've just remembered there's a bike garage in taplow called PDQ. They worked wonders dynojetting my old 600F. Spent ages setting it up and afterwards it was perfect.
They do suspension too so maybe they're worth talking to.. 13 miles vs 130 does sound more appealing  ____________________ CBR954RR - Daily toy
| evoboy |
 evoboy World Chat Champion
 Posted: 23:50 - 27 Jul 2015 Post subject: |
Does the bike feel like it 'understeers' or runs wide when in a corner?
I would try backing off the compression adjusters in the forks a few clicks or quarter of a turn. See if this improves how the suspension reacts to bumps.
How much fork travel is it using under heavy braking? Put a cable tie on the fork slider and see how far it travels.
The rebound may also be set too slow so the forks dont have the time to return after hitting a bump.
All speculation without having the bike to play with unfortunately. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Pigeon |
 Pigeon World Chat Champion
| struan80 |
 struan80 World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
 Posted: 00:46 - 28 Jul 2015 Post subject: |
you sure the frames straight?
motoliner can check and straighten it. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| sickpup |
 sickpup Old Timer
| supZ |
| sickpup |
 sickpup Old Timer
| mfactor |
 mfactor Nova Slayer
 Posted: 15:45 - 29 Jul 2015 Post subject: |
Its not done this before , you fitted different front tyre , it started playing up ,, dunno but all the clues are there.
But to be serious I used to fit tyres and you would be amazed at some weird shit mismatched/faulty tyres can cause.....
My thoughts are that the tyre caused the problem , you have now changed that but your confidence is shot, just take it easy and see how it goes............... |
| Acemastr |
 Acemastr World Chat Champion
| chris-red |
| orac |
 orac World Chat Champion
 Posted: 19:34 - 29 Jul 2015 Post subject: |
I am just going to put this out there seeing as it hasn't been mentioned as yet. rear suspension linkage bearings. I have only ever had 2 set go completely and on lower powered bikes, don't know what they would do on something with the poke of a blade.
also:
https://www.youtube.com/watch?v=LmHU-gtlOKo ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| supZ |
The last post was made 11 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
