Shuddering Front Brakes
Moo.
PostPosted: 17:25 - 02 Aug 2015    Post subject: Shuddering Front Brakes Reply with quote
Started to notice my front brakes shuddering, or an on/off feel accompanied by a swoosh-swoosh-swoosh sound on the front rotors.
Typically i thought it may be warped discs.... But 3 pairs of front disks later, they all do the same thing. All discs will sit flat on a piece of glass
Also only scraped past the MOT as he said the braking power was fluctuating massively on/off but passed it because all the pads/rotors were new so could possibly be put down to not being bedded in...
So when pulling the lever, its more pronounced at slows speeds, but you can feel the brake power going on and off when it passes a certain point and creates a jerking braking movement when stopping...
Anyone have any ideas?
A2 Passed 18/6/10
PostPosted: 17:29 - 02 Aug 2015    Post subject: Reply with quote
New disks AND pads or just disks?
Have you considered overhauling the calipers?
PostPosted: 17:32 - 02 Aug 2015    Post subject: Reply with quote
+1 to pointing the finger at calipers if the pads have also been changed.
Moo.
PostPosted: 17:33 - 02 Aug 2015    Post subject: Reply with quote
New pads and discs. Calipers haven't been overhauled, they're blue spots... Seen a kit somewhere that let's me take the star blank plate off...
A2 Passed 18/6/10
PostPosted: 19:11 - 02 Aug 2015    Post subject: Reply with quote
Get a dial guage on the discs while they're on the wheel.
I had a problem with fluctuating brake effort on Mrs stinkwheels CB500 and it eventually turned out (after replacing/overhauling literally everything on the braking system) that there was an uneveness on the posts the disc bolted to.
I eventually sorted it by putting shims between the disc and wheel at the "low" points. Very thin (0.1mm) shims at that. Doesn't take much to make the runout exceed tolerances.
This probably wouldn't have been a problem with floating discs.
Mind you, a sticking piston can cause the pads to chatter too but if you have accfess to a DGI, it's free and easy to check the runout.
The last post was made 11 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 43.46 Kb
