| joezxr |
 joezxr Nova Slayer
 Posted: 17:38 - 03 Aug 2015 Post subject: Bike wont lean to the right!? |
I have a 2003 zx6r ( b1h) and when i lean to the right it becomes very unstable, the front end gets a slow wobble and it feels like if i lean any further im going to drop off the face of the earth the weird thing is it leans to the left absolutely fine!
Iv changed my headstock bearings, had my forks oil and seals replaced, changed my front wheel bearings, torqued everything up, set my suspension up evenly, checked my swingarm and rear wheel bearings for freeplay, and made sure my wheel alignment is straight and its all normal...
my last idea is it may be my tyres, but they dont seem to show any uneven wear.
Does anybody know what this could be?
cheers |
| MCN |
 MCN Super Spammer
 Posted: 17:48 - 03 Aug 2015 Post subject: |
Simple:
Pressing the brake/break lever as you lean over.
Bent twisted front fork.
Helluva Camber on the road where you are.
Complex:
Twisted Frame Swing Arm which changes geometry when cornering and under compression.
Something more simple or sinister.  |
| mentalboy |
 mentalboy World Chat Champion
| TheManWithThe... |
 TheManWithThe... Brolly Dolly
| MarJay |
 MarJay But it's British!
| MCN |
 MCN Super Spammer
| MarJay |
| joezxr |
 joezxr Nova Slayer
| joezxr |
 joezxr Nova Slayer
| brains_t |
 brains_t Nitrous Nuisance
| MCN |
 MCN Super Spammer
| joezxr |
 joezxr Nova Slayer
| joezxr |
 joezxr Nova Slayer
| MCN |
 MCN Super Spammer
| Sload |
 Sload World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 21:33 - 06 Aug 2015 Post subject: |
It's an auld trick for checking truck chassis alignment.
For that you drop plumb bobs from matching parts of the chassis at various point.
Chalk mark the point they touch on the floor.
Measure the distance between the marks on diagonals.
Compare the measurements.
If the chassis is true both should be the same.
I find the string-bike thing is easier than the plank of wood method as the string is straight but the wood can be warped. (Not that Warped).
If you only use the wood you must allow for the warpage-ness in your calculations too.
I have a little laser thing for aligning a telescope mirror. I wanted to modificate that to use as a laser alignment tool on the bikes.
It would need a bit of steel work though but more pressing projects on the go so laser alignment on to-do list. |
The last post was made 11 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
