96 Suzuki RM80 leaking fluid out of engine exaust
tazer887
PostPosted: 22:05 - 05 Feb 2005    Post subject: 96 Suzuki RM80 leaking fluid out of engine exaust Reply with quote
I got a used Suzuki that won't start. Compression seems to be ok doing the "hand over the spark plug hole" and I have a spark but it won't turn over. I inspected the carb and replaced the head gasket but no luck. After repeating kick start attempts it spews out liquid out of the engine exaust before it hits the pipe (right under engine). The liquid seems to be a mix of gas and antrifreeze. Anyone have any ideas?
Thanks in advance.
-Tazer
PostPosted: 22:09 - 05 Feb 2005    Post subject: Reply with quote
If there is antifreeze in the exhaust system, either:
1) The cylinder head gasket has blown and needs replacing. (most likley and simple to repair if the head isn't warped/damaged)
or
2) The water jacket has cracked in which case you need a whole new top-end.
tazer887
PostPosted: 18:34 - 07 Feb 2005    Post subject: Reply with quote
Thanks I'll give the cylinder gasket another shot. When I initially replaced it, I found the old one was broken and even a little melted. I'll take extra care to make sure I get rid of all the old gasket this time. Anything else I should be paying attention to?
Thx
-Tazer
PostPosted: 19:49 - 07 Feb 2005    Post subject: Reply with quote
When you have the cylinder head all cleaned up, place it flat on a sheet of glass and see if it rocks about. If it isn't perfectly level on the glass, it is warped and needs to be refaced/skimmed.
The old fashioned way for fixing a slightly warped head is to smear some fine grinding paste on a sheet of glass and rub the gasket surface on it in small, random circles being careful not to put downwards pressure on it. After about two hours you will find that the sound changes, the head 'sticks' to the glass and the entire gasket surface has a polished appearance which shows it is now perfectly level (providing the glass was). Rinse ALL the grinding paste off with numerous changes of a solvent such as petrol.
The modern way is to pay an engineer to skim it with a machine.
Ensure the facings are totally clean before installing the gasket and tighten the bolts down gradually in a crosswise pattern using a torque wrench.
The last post was made 20 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 40.41 Kb
