| Vincent |
 Vincent Banned
 Posted: 12:26 - 04 Aug 2015 Post subject: Undoing Bolts With A Torque Wrench |
Will it give you an accurate idea how much they were tightened? I'm guessing not as bolts seize when they've been in a while. The reason I ask is because I just undid all the cylinder head bolts on the GT with the torque wrench set at 10 ft-lbs The m8 bolts are supposed to be 13 to 15.9 ft-lbs.....the M10 ones, (elongated nuts), 21.7 to 29 ft-lbs If that's correct, no wonder the head gasket had blown. ____________________ Space Is Deep |
| lihp |
 lihp World Chat Champion
| Fisty |
 Fisty Super Spammer
| lihp |
| Fisty |
 Fisty Super Spammer
| MCN |
 MCN Super Spammer
| lihp |
| Matt B |
 Matt B World Chat Champion
| CaNsA |
 CaNsA Super Spammer
| MCN |
 MCN Super Spammer
| Fisty |
 Fisty Super Spammer
 Posted: 14:08 - 04 Aug 2015 Post subject: |
| MCN wrote: |
What is a stretch bolt?. |
A bolt that is designed to stretch. Usually used once then renewed when rebuilding.
Citroen/Peugeot head bolts on the TU5 engine use them.
| Quote: | All bolts stretch when they are tightened, but usually they stay within their 'elastic limit'. So, when they are loosened, they return elastically to their original length.
The normal tightening method is by torque wrench. The tightening torque is calculated to apply the correct stretch, and so put the correct load on the joint. It's not very accurate, and is affected particularly by thread condition, lubricant on the thread etc. Even using a bolt a second time when the thread is polished gives a different load on the bolt.
Stretch bolts try to eliminate some of these problems. A steel bolt will extend steadily in proportion to load up to its elastic limit. At that point it yields, and takes on permanent deformation. For a short while the material continues to extend steadily for very small increases in load (the load/extension curve being virtualy horizontal), and after that it takes only very small loads to keep stretching it to the point of failure. That is the load/extension curve drops rapidly. Stretch bolts are made of steel which has a relativly long horizontal section of the load/ extension curve past the yield point. In use they are tightened by stretching them a specific amount, by measuring the rotation after the joint is nipped. This is calculated to take them a short way past their yield point, to the point where the load extension curve is horizontal. The load in the bolt and hence the load on the joint is accurately known, as opposed to being at some ill-defined point on the elastic part of the load extension curve.
Because the deformation is permanent, and further extension would actually reduce the load applied, it is not possible to check the tightness of such bolts after a period of service. It is also unwise to reuse them, as they would not apply the correct load to the joint. |
Because I'm too lazy to type it out. ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| Fisty |
 Fisty Super Spammer
| MCN |
 MCN Super Spammer
| CaNsA |
 CaNsA Super Spammer
 Posted: 14:51 - 04 Aug 2015 Post subject: |
surely a torque wrench will work on reverse threaded bolts...  |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| bikenut |
 bikenut World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 19:15 - 04 Aug 2015 Post subject: Re: torque |
| Paddy Blake |
| Vincent |
 Vincent Banned
| Paddy Blake |
| Vincent |
 Vincent Banned
| lihp |
The last post was made 11 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
