please help. brake lever with no resistance
pompousporcup...
PostPosted: 21:29 - 05 Aug 2015    Post subject: please help. brake lever with no resistance Reply with quote
I've had a nightmare trying to bleed my gpz brakes and am at the end of my tether. Please help confirm diagnosis
I substituted a known working caliper to my bike as the other was sticking. Big piston was fairly seized
I've tried 3 methods now. The pump the lever squeeze and hold - open the nipple, close the nipple release which saw fluid come out as expected. Couldn't get a steady stream with the one way valve type tube.
Tried leaving the bleed nipple open and pumping the brakes with the one way valve but this didn't seem to do much as the fluid kept going back in, never a consistent stream.
Tried the open bleed nipple, pull lever - close nipple and release method without success. Same problem.
Also tried the above without the one way valve...clear tube from bleed nipple with the other end submerged in some fluid..nope.
Assuming an air lock at the top of the system, Today I went and got some syringes from the local pets and home, although only 20ml ones, and used some new clear tube to back bleed the system. Sure enough bubbles came out the MC and I flushed the rest of the old fluid out this way... Still no effing resistance on the lever Sad
I then bled it the conventional way to release any bubbles but there weren't any.
Wtf is wrong? Crappy MC?
Fwiw I've bled many a car system without issue so know what is meant to happen but this has me stumped.
Edited for android failures.
Just_James
PostPosted: 21:36 - 05 Aug 2015    Post subject: Reply with quote
Had the same issue recently (on completely different bike) with trying to bleed a front brake from dry after rebuild. Did everything just like you've tried and literally spent hours getting nowhere!
Tried the trick of clamping the lever closed with a cable tie and leaving overnight to let air escape which helped a little but never got a decent feel to the lever.
Ended up buying a cheap (around £13 iirc) vacuum bleeder kit off the bay and that it had it sorted in minutes! Very worthwhile investment in a handy bit of kit Thumbs Up
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
pompousporcup...
PostPosted: 21:42 - 05 Aug 2015    Post subject: Reply with quote
I've tied the lever 3/4 closed now to leave over night. Is it worth closing it all the way?
It's disheartening. This is the third night Ive tried to get this done with only a little time after work. 1.5 hours a night Sad
Fisty
PostPosted: 22:16 - 05 Aug 2015    Post subject: Reply with quote
Bleed the master cylinder first. Crack the banjo bolt on the m/c and bleed it like you would a caliper.
Fatter and faster than Fret
pompousporcup...
PostPosted: 22:25 - 05 Aug 2015    Post subject: Reply with quote
By pulling the lever with the mc banjo bolt open then close bolt and release?
Fisty
PostPosted: 22:31 - 05 Aug 2015    Post subject: Reply with quote
Yup. Then do the rest of the system again.
pompousporcup...
PostPosted: 22:57 - 05 Aug 2015    Post subject: Reply with quote
Ok, thanks fisty. Will give it a go and report back.
I've ordered the 15quid vacuum bleeder as well just in case as i'm still waiting on new discs and time to rebuild the other caliper, so this will need tobe done in a few months time. It stopped being fun after the first couple of hours Evil or Very Mad
MCN
PostPosted: 23:12 - 05 Aug 2015    Post subject: Reply with quote
Maybe too late to stop the postman.
I have tried vacuum bleeders, big ef-off enema syringes, and 'tying back the lever and going to bed. All were fruitless.
The easiest way to get air out the brakes, unless you have patience, is with a pressure bleeder.
Gunsons make a one. It works very very well and the result is a sweet and solid lever every time.
Some folk are over-concerned about the fact of pushing brake fluid with air. I used it and never had to look at the brake again.
You only need a little over atmospheric (from one the bike's tyres) to push the fluid through so it's not like a Sodastream.
The only phaph was to modificate a reservoir cap to fit the bottle.
The tool comes with a few different caps but I think for cars. I bought a new cap and drilled a hole (as in the Gunson caps).
pompousporcup...
PostPosted: 23:22 - 05 Aug 2015    Post subject: Reply with quote
That's why I haven't bought one yet. They dont make it with a cap for bike reservoirs. As far as I've seen anyway. They seem good value but having to sacrifice something to get it to work seems the hard way around. Hadnt actually considered drillling a spare cap. I have one. Last resort maybe
MCN
PostPosted: 00:47 - 06 Aug 2015    Post subject: Reply with quote
I gave the one I had modificated to a 'mate' who liked it so much he hasn't borrowed me back. Sad
I bought another last year with a mind to do the Mrs' ER6 change. When I get a roundtoit.
I was past caring about cost when I bought the first one but almost came (Hard) when the results was so positive.
Worth a punt if you reach desperation.
The brutal fact is the brake will bleed if all is well mechanically.
We have a CG125 which I fitted a braided line to the front disc. Wouldn't bleed at all.
I removed the brake lever and turned it to get the bleeder on the Master cylinder exactly at it's highest point. Bled the air out of there then removed the calliper and did the same thing.
Brake was good after that. But a phaph.
skatefreak
PostPosted: 09:22 - 06 Aug 2015    Post subject: Reply with quote
Been here as well.
After about 2-3 hours of getting no where fast I just got mighty Pi$$ed off at it. Put the cover loosely on the master cylinder and furiously moved the lever back and forth as fast as humanly possible...
Went proper potato tantrum on it and low and be hold, job jobbed Wink
That was from a completely dry calliper though.
Never had the trusty old Compress, Open bleed, Close bleed, decompress, repeat fail :\
-Jvr
MCN
PostPosted: 09:56 - 06 Aug 2015    Post subject: Reply with quote
The problem on bike brakes is that to provide for powerful braking effect the master cylinder piston square area is tiny compared to the wheel cylinder/calliper piston square area. This is to provide the mechanical (hydraulic leverage) advantage. As gears do in a transmission.
It's like trying to fill a swimming pool with a bucket (sort of). It will get full but maybe sometime next week.
PostPosted: 10:22 - 06 Aug 2015    Post subject: Reply with quote
I've never failed to bleed brakes by simply opening the nipple, attaching a tube from the nipple to a pot of waste fluid, making sure you keep it under the fluid level, then squeezing the lever repeatedly.
PostPosted: 11:12 - 06 Aug 2015    Post subject: Reply with quote
Bleeding at the banjos will almost certainly sort it out.
Wrap a cloth round the banjo, start pulling the lever then open and close the banjo quickly before the lever reaches the end of its travel.
If you hear a sharting noise, that's air coming out. Keep at it until you're just getting fluid.
bikenut
PostPosted: 12:23 - 06 Aug 2015    Post subject: bleed Reply with quote
you do realize that if the m/cylinder is full of fluid with the cover off, and the brake hose goes down hill to the caliper, and the caliper bleed nipple is open, then the fluid will flow down into the caliper all by its self??
that is assuming the bleed nipple and the tiny recouperating port in the m/c aint blocked! and there is some free play tween brake lever and m/c piston!!!
always get the m/c to pump fluid first.........suitable rag paint protection, thumb ( or finger, or screwed devise ) over pressure hole, and gently pump, then cover hole ( so fluid drawn into pressure swept volume chamber ) and watch fluid drawn into that CHAMBER, THEN PUMP........then fit hose etc and watch it syphon from the caliper bleed nipple. when no bubbles, bleed the conventional way.
do not let the fluid tank ( htf do you spell reservuar ) run out of fluid.
of all the bike brakes I have bled I have never had a problem doing it this way.....htf do you think they do it in the factory!! ( pressure bleeding probably ) wait overnight??
nuts about bikes
MCN
PostPosted: 12:58 - 06 Aug 2015    Post subject: Re: bleed Reply with quote
Y they no do nite shift?
pompousporcup...
PostPosted: 21:32 - 06 Aug 2015    Post subject: Reply with quote
Thanks all.
Bled the upper banjo bolt, heard the described sharting noise and FINALLY started getting resistance in the lever. Also noticed little bubbles coming out in the reservoir at each pull of the lever so did about 30 pulls...job jobbed Smile
Its not perfect but stops me from 60 in the distance it did previously but I think the pads are half warn. Will hopefully see tomorrow if the binding has gone but it seems to coast better now from the short test run
left the lever tied down over night for good measure.
Yaay for riding again.
MCN
PostPosted: 21:46 - 06 Aug 2015    Post subject: Reply with quote
sharpe2002 wrote:
Thanks all.
Bled the upper banjo bolt, heard the describes sharting noise and FINALLY started getting resistance in the lever. Also noticed little bubbles coming out in the reservoir at each pull of the lever so did about 30 pulls...job jobbed Smile
Just for argument's sake, your pads should stop as well from new as the will when worn almost to the backing.
Disc brakes self adjust as the pads wear so your lever travel remains the same it's just the brake fluid that will drop.
It is a good indicator for pad wear when the fluid looks like it needs topping up then the pads will probably be near goosed.
I never top up if still above the low line.
If you do top up then you will have to un-top up when you renew the pads next time. As you push the pistons back in the extra fluid will be pumped out the res. Onto your tank/patent bike boots.
There nowt like getting a pig's beast back on the road again. Thumbs Up
pompousporcup...
PostPosted: 08:54 - 07 Aug 2015    Post subject: Reply with quote
that's a good point, hadn't considered that.
Leaving it over night got a bit more resistance in the lever so it now nearly matches my buddies cbf6. Seems to stop well enough for my riding style. Fix one thing, another breaks.. Mad
The last post was made 11 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 108.54 Kb
