| UncleFester |
 Posted: 21:35 - 06 Aug 2015 Post subject: VFR800FI - general tidyup |
Not much to write about yet as i've only just had the thing delivered. Bit of a cleanup and general tidyup ready for next spring.
The basics?
1999 VFR800FI in Italian faded red. Full Service History and a very recent big service. Had all its seals and clearances etc done. New oil and filter, fresh filters and a clean tank of fuel.
Done -
Replaced the rotten downpipes for SS ones
Replaced the oil cooler hard lines for nice non corroded ones.
To be done
Clean up and spray the wheels.
Sort out the faded plastics either by respray or by fitting a set of rinkydinky chinese fakes.
Polish up and fit rear seat cowl.
Polish up and refit the hazed and faded screen.
Find a set of matching mirrors.
Sort out the dash issues either with new lamps or by doing some careful soldering of any burnt / corroded tracks on the instrument circuits.
Anyway pic of it nestled into its storage spot for the next few months whilst i work on it.
https://i104.photobucket.com/albums/m172/unclebloodyfester/VFR800FI/11234967_10152983639105264_5133692348182234819_n_zpsfgufg6md.jpg ____________________ 2017 Z1000SX |
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 00:19 - 07 Aug 2015 Post subject: |
Nice project! Do have a bit of a soft spot for the old VFRs
That's 'just a do' fit in there though eh? Looks like you built the garage around it!
How do you use the door though?  ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| UncleFester |
 Posted: 06:51 - 07 Aug 2015 Post subject: |
Rented garage - the door isn't used and yes, a tight fit and yes, i did have to measure it before i bought the stand / bike  ____________________ 2017 Z1000SX |
| Scootaloo |
 Scootaloo Could Be A Chat Bot
| UncleFester |
| UncleFester |
 Posted: 18:23 - 09 Aug 2015 Post subject: |
Had the front fairing off today. Wet sanded the screen and fairing, now both are shiny.
Also had the dash to bits and found the cause of no flashing hazard dash lights .... no lamps in the sockets On the down side, the reason they'd been taken out is because they both flash at once. I know the problem is either in the PCB or a duff earth somewhere so next time it all comes to bits i'll do some digging as well as some general earth cleaning.
Removed the nasty rear rack and fitted the rear cowl. ____________________ 2017 Z1000SX |
| UncleFester |
 Posted: 21:36 - 10 Aug 2015 Post subject: |
PCB faults all fixed. Indicators now flash on the correct side and the dash illumination all works as it should  ____________________ 2017 Z1000SX |
| UncleFester |
| UncleFester |
The last post was made 11 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
