| Scootaloo |
 Scootaloo Could Be A Chat Bot
 Posted: 09:49 - 07 Aug 2015 Post subject: My First Project - VF500 |
Hello All
So after owning 6 bikes I have started doing my own shit and long story short, ended up buying a restore project! - "Would you like to see?" the sarcastic child's TV show presenter said.
Well here it is, on the day I bought it:
https://s7.postimg.org/z50bsnlvv/VF_front.jpg
https://s8.postimg.org/idi4kb09h/VF_side.jpg
MMM - That purple.
To be continued... ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
| Scootaloo |
 Posted: 10:07 - 07 Aug 2015 Post subject: |
Started doing the basic stripping... bolts and nuts all coming off a breeze with GT85!
Already we've got a few parts that will never go back again...
https://s15.postimg.org/ecgvyvqmj/old_parts.jpg
The radiator is missing several fins and the clocks are broken..
Most of the wiring loom is butchered.
Well.. maybe the tank isn't that ba... oh my! - https://s15.postimg.org/h7tz5qumj/old_tank.jpg
https://s15.postimg.org/kow18ptor/oldtankdent.jpg
Um.. well... forwards then... ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
| Scootaloo |
| Scootaloo |
| Scootaloo |
 Posted: 11:32 - 07 Aug 2015 Post subject: |
Got help from a friend. Using the latest CGI I have managed to conceal their identity from this forum:
https://s11.postimg.org/e8jw8iqeb/assistant.jpg
Remember those shitty old exhausts? Well behold! Cleaned up old exhausts... https://s11.postimg.org/igeoh9rtv/shiney_exhaust.jpg ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 12:26 - 07 Aug 2015 Post subject: |
looks like progress
I hate the cleaning part. Thats why i've had a frame sat for ages waiting.. the strip down is the best bit  |
| Scootaloo |
| Scootaloo |
| Scootaloo |
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 20:34 - 07 Aug 2015 Post subject: |
Looks like you're doing a good thorough job with this
Keep the posts and pics coming! ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| .Chris. |
 .Chris. World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
| Scootaloo |
 Posted: 10:28 - 10 Aug 2015 Post subject: |
Part availability has been Ok so far. A lot of these bikes are Granadering themselves at this point so there's always plenty of parts. The most rare part by far is the tank...
Paint dry: https://s30.postimg.org/6o21rrd69/frame_top.jpg
https://s30.postimg.org/5khxfssj5/frame_middle.jpg ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
 Posted: 19:57 - 10 Aug 2015 Post subject: |
Simoniz Wheel Silver comes out an almost perfect match for those Honda frames. I used it on my VF1000 after getting a tip and you couldn't tell where the old paint met the new. ____________________ a.k.a 'Geri'
| Scootaloo |
 Posted: 09:45 - 11 Aug 2015 Post subject: |
Got my shock back from HM racing, excellent service top recommendations there.
https://s18.postimg.org/3wf77qlop/Fixedshock.jpg
When installing my headrace bearings I accident-ed them and ended up exploding them all over the garage... oops!... New £20 set on the way.. expensive learning curve.
Decided to take a look at the engine timing for cams and valves, this is my first time doing this so I hope I've set them correctly! The feeler gauges don't seem to give you a create deal of accuracy just "oh its about that much there you go..." anyhow I think it should make a big difference as all the valves were all rammed shut at TDC.. the engine has covered 40,000 miles so far.
https://s18.postimg.org/6p3cunfpl/engine_timing.jpg
https://s18.postimg.org/3wa5amfd5/cam_timing.jpg ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
| Scootaloo |
 Posted: 10:36 - 11 Aug 2015 Post subject: |
Disaster Strike - it seems what I though was the bottom layer of paint was actually covering up some plastic... not a problem until I tried to plug a small hole with some brass. The plastic caught fire and then the solder underneath melted!!!
https://s9.postimg.org/62vs5n87z/engine_brassing.jpg ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
| Scootaloo |
 Posted: 09:36 - 12 Aug 2015 Post subject: |
Whilst I figure out what to do with that. My headstock bearings arrived... and then this happened: https://s9.postimg.org/fl2nhpjsf/frame.jpg
Spot the mistake.... ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
| delsol |
 delsol World Chat Champion
| andym |
 andym World Chat Champion
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
 Posted: 11:44 - 12 Aug 2015 Post subject: |
Impressively quick progress so far. Good job
Sure I read an article a year or two ago (maybe in BIKE magazine) where they do these up with new cycle parts and race them, primarily in Japan.
New swing arms and forks etc off of CBR and VFR 400's etc. Ever considered doing that or after a standard restoration? ____________________ Pictorgraphicalfantastical |
| Scootaloo |
| Scootaloo |
| MarJay |
 MarJay But it's British!
| Scootaloo |
 Posted: 10:27 - 13 Aug 2015 Post subject: |
Then the engine fell off the bench into the frame...
https://s7.postimg.org/a98cvyvzf/engine_in.jpg ____________________ (CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87) |
The last post was made 11 years, 44 days ago. Instead of replying here, would creating a new thread be more useful? |
