| kevinheb |
 kevinheb Two Stroke Sniffer
 Posted: 12:21 - 09 Aug 2015 Post subject: Turn key and absolutely nothing happens |
I have a BMW F650CS 02. Normally when you turn the key from "off" to "on" the bike makes a whirring noise and the display lights come on for a few seconds. I haven't ridden the bike for a couple of weeks, and last night when I tried to start it, when I got on the bike with the key in "off" position, the time on the display was showing. When I turned the key to the "on" position, absolutely nothing happened. No lights on the dash, the time lcd went blank, and the bike made no whirring.
When I turn the key to the "off" position again, the time reappears, and the speedo vibrates for a few seconds and I can hear a quiet whirring coming from the bike for a few seconds.
I believe that the battery is ok, with a multimeter across the battery the voltage is 12.5V and I have tried charging the battery, but the charger says that the battery is charged. I have also checked the fuses with the multimeter, which says that the fuses have no resistance across the them.
I'm at a real loss to work out what is wrong with the bike, and would appreciate any advice, thanks ____________________ YBR 125 (sold) > YBR 250 (sold as spares/repair) > F650CS |
| kevinheb |
 Posted: 12:49 - 09 Aug 2015 Post subject: |
More likely you turned the key to far and ran it flat with the parking light. ____________________ a.k.a 'Geri'
| bugeye_bob |
| mentalboy |
 mentalboy World Chat Champion
| kevinheb |
| doggone |
 doggone World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 13:05 - 09 Aug 2015 Post subject: |
A new battery will be about £60+.
A Battery conditioner about £40.
You really should have both in your case. If you leave the bike for any length of time a month or two without any action it can ruin a battery quickly.
Conditioners help keep the battery in top nik so they should last longer over all.
I would:
Try to charge the battery and test if it'll start the beast.
If not, buy a new battery.
Then you need to buy a conditioner for maintenance and less butt-hurt.
Keep the top of your battery clean too.
A wee test:
If you have your multimeter handy, connect one lead to a post.
Touch/Drag the other lead around the top of the battery.
Observe the voltage reading.
Wipe off any shit etc. from the top of the battery and re-test.
It's not massive amps, volts, ohms etc. but it is a trickle or constant drain 24/7.
Your trickle charger/optimizer will easily accommodate for this 'leakage'. |
| Taught2BCauti... |
 Posted: 13:27 - 09 Aug 2015 Post subject: |
FWIW, I also think you have a battery problem.
Sometimes when a battery fails, a voltmeter appears to show that everything is fine, but internally, the current capacity isn't up to the job.
Measure the voltage again with the ignition on, and see if you get a lower reading.
This is why the battery charger says "Full", because it can't get any more juice into it.
You need a special piece of equipment called a 'Drop Tester' to measure the battery capacity - a multi-meter won't do it. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| doggone |
| MattEMulsion |
 MattEMulsion World Chat Champion
| kevinheb |
| kevinheb |
| barrkel |
 barrkel World Chat Champion
 Posted: 17:02 - 09 Aug 2015 Post subject: |
| MCN wrote: | If you leave the bike for any length of time a month or two without any action it can ruin a battery quickly. |
I'd love to see evidence for this; specifically, such a short time without use, and a quick death.
My experience is contrary. Take my VFR for example; I very rarely ride it over winter, and it can go a month or two without riding after I've come back from my last tour of the summer; I'd say it does at least three 1..3 month periods of disuse a year. It's still using the battery I bought it second hand with, a battery that is at least 3 years old, and has been through two reg/rec failures and two stator failures, both times being ridden on battery alone until no more spark. And it still starts on a button press.
Or my GF's ER6f. Pretty much never ridden apart from ~2 tours in the summer, so it goes 9+ months of the year without being ridden. The original battery died last year, after 5 years of this treatment.
Our bikes live outside and there's no easy way to run power to them. Dragging the batteries inside to keep them charged there might make them last longer than 5 years, but IMO it's not worth the hassle or clutter. The batteries are cheap and hardy enough that the space and labour of moving them around exceeds the cost of buying them new a couple of times a decade.
A faulty charging system would kill a modern battery much faster than neglect, IMO. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Snodvan |
 Snodvan Spanner Monkey
| MCN |
 MCN Super Spammer
 Posted: 22:37 - 09 Aug 2015 Post subject: |
| barrkel wrote: | | MCN wrote: | If you leave the bike for any length of time a month or two without any action it can ruin a battery quickly. |
A faulty charging system would kill a modern battery much faster than neglect, IMO. |
Aye OK but I have experience from loads of batteries not maintained properly and they don't put out the same power as a maintained battery.
If the starting load is considered, you may get five/six/more start cycles from a good battery but one that has not been looked after may not be as forgiving and die after three or four goes.
A month or two is possibly not long enough but more than that is going to knacker a battery.
Some designs are more able to accept a bit of abuse but the budget ones fall at the first fence. |
| kevinheb |
| davebike |
 davebike World Chat Champion
 Posted: 11:50 - 10 Aug 2015 Post subject: |
Could be BMW's inigtion switch wire snapping I seen it more on the bigger bikes
turn on inigtion check battery voltage is good (still over 12v)
check voltage at fuse box ( not main fuse )
If no volts there
Look at the wire from the inigtion switch you have to cut and remove the plastic sieve the wires tend to brake near where there are cable tied to the frame and turning the steering flexes them ____________________ Dave
NC750Xdct + others at work !
[email protected] |
The last post was made 11 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
