Car - clutch gone
DrDonnyBrago
PostPosted: 22:19 - 11 Aug 2015    Post subject: Car - clutch gone Reply with quote
Hi all,
1.6 mk2 ford focus.
It's my wife's car, I drove it the other day to find the clutch quite high and juddering a tad. Didn't slip. Haven't driven it in a few months but surprised it had deteriorated so quick (prob about 600 miles, it isnt used much), assumed slave cylinder leak as it explained the high clutch and the juddering.
Come today, clutch felt as above then suddenly went as I changed up. I had only a tiny amount of drive from the clutch, slipping like mad and burning up.
I'm getting a new clutch kit with slave cylinder, but I can't figure out why it would go so quickly. Can't be fluid leak or pressure as it would have locked in, and not disengaged, not slipped. I'd be surprised if it was normal clutch wear as it progressed so rapidly, then went instantly. Thoughts? I'm thinking clutch springs or maybe the friction plate falling apart.
Ichy
PostPosted: 22:28 - 11 Aug 2015    Post subject: Reply with quote
Nothing really to add but was there any particular noises you noticed? Might be the thrust bearing collapsing.
MattEMulsion
PostPosted: 22:42 - 11 Aug 2015    Post subject: Reply with quote
Has it got a dual mass flywheel?
Yamaha YZF-R6
Carvel
PostPosted: 22:44 - 11 Aug 2015    Post subject: Reply with quote
It should be obvious once the box is off.
As mentioned later cars suffer with dual mass flywheel issues.
MCN
PostPosted: 22:51 - 11 Aug 2015    Post subject: Reply with quote
DMFs are normally fitted to Diesels. The idea is that the mass of the flywheel dampens the harsh pulsation of Diesel combustion cycle.
A clutch can be OK and suddenly let go if worn and then given a bit of a horsing.
How many miles on it?
DrDonnyBrago
PostPosted: 23:02 - 11 Aug 2015    Post subject: Reply with quote
Petro 65 k milesl, pretty sure it is a standard flywheel. I remember checking before buying it as I didn't want a dmf car.
No noises, literally just went in a split second. Thought I'd fucked up a gear change.
binge
Emo Kiddy
PostPosted: 23:13 - 11 Aug 2015    Post subject: Reply with quote
1.6 Focus has a solid flywheel.
Probably one of the easiest clutches to change. Think the only ones I do faster are on the 1.4 and 1.6 TU engines fitted to Cit/Peug cars.
They generally will go pretty quickly once the clutch friction has worn away so much.
The cover plate doesn't squash up tight enough to the flywheel to grip the clutch plate once it's near enough on the rivets.
Once the slipping starts, it's quite a rapid run to a non-driving car.
Had the slave gone, you'd have lost the pedal.
BTW. They are CSC (Concentric Slave Cylinder). It's inside the Bell housing. So 100,000% make sure you change it while it's apart. Thumbs Up
misscrabstick
PostPosted: 23:32 - 11 Aug 2015    Post subject: Reply with quote
A leaky slave cylinder that let air in and fluid out would usually make the clutch hard to disengage because it would reduce the travel of the clutch release mechanism, it would never cause slipping or a "high" pedal.
Focus clutches are pretty easy to fit usually about 3 or 4 hours.
binge
Emo Kiddy
PostPosted: 23:34 - 11 Aug 2015    Post subject: Reply with quote
3 / 4 hours? Which main dealer do you work for then? Razz
On the floor, that's probably a reasonable time. Any decent clutch fitter, with a ramp and a pump stand should be doing them in well under 2.
DrDonnyBrago
PostPosted: 08:59 - 12 Aug 2015    Post subject: Reply with quote
Interesting to know thanks Thumbs Up .
The last post was made 11 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 64.81 Kb
