RS125 forks (help)
rizo9
PostPosted: 12:23 - 06 Feb 2005    Post subject: RS125 forks (help) Reply with quote
i have taken my front wheel out ready for new tyres,
went to rest the bike on the forks and the right leg just went all the way in .
it does return slowly but not fully,
tried the left one and it was fine.
what is wrong with it?
can any one help me
thanks
New bike Very Happy https://www.bikepics.com/members/rizo9/01rs125/
Scotsman37
PostPosted: 12:39 - 06 Feb 2005    Post subject: Reply with quote
You need fork oil in it because that sounds like it's completely leaked out over time. So you require new fork seals and bushels with new fork oil except the fork spring(s) may needed inspected to make sure they don't let the forks dive down to far..
It can be a messy job and the fork oil has to be of a certain volume inside and if it's to high then it can possibly leak pass the fork seals or if it's to low then it will be the same as mentioned in the 1st paragragh.
So get the correct fork oil as noted in your manual for your bike and replace the fork seals & bushels with new ones rather trying to use the old ones because the old ones are probably leaking anyway !
P.S. You shouldn't have rested it back down on it's forks as you might have gone and damaged some other part of the bike or it could have landed on you !
If it's an Aprilia RS125 that your talking about and think you'll like this site as you can download user manuals and a workshop service manual pus other things of interest too.
https://www.aprilialand.com/nuke/html/modules.php?name=Downloads&d_op=viewdownload&cid=10
cagiva gezzer
PostPosted: 13:23 - 06 Feb 2005    Post subject: Reply with quote
Or just put it all back together and it will be fine. Small capacity bikes ahve one sprung leg and one damper leg...
Dom_
Points Mean Prizes
PostPosted: 17:09 - 06 Feb 2005    Post subject: Reply with quote
Yep, as Cagiva geezer said. The rs125 has a spring in only one leg, so will not work well on it's own, but when coupled with the other fork it should work as normal.
PostPosted: 22:35 - 06 Feb 2005    Post subject: Reply with quote
Yes, perfectly normal for an RS125 fork.
Scotsman37
PostPosted: 07:24 - 09 Feb 2005    Post subject: Reply with quote
Here's a link to download your user's maintenance manual just in case you don't have one;
2001 manual;
https://www.serviceaprilia.com/public/lumAprilia/RS%20125/English_2001.zip
There is a gap of 12 years, 111 days between these two posts...
Calum122
PostPosted: 14:18 - 28 May 2017    Post subject: Reply with quote
Excellent thanks a lot. I was unsure why only one leg had a spring in it. Thanks for clearing that up.
Always Originate, Never Pirate
Formerly known as
P.
PostPosted: 14:20 - 28 May 2017    Post subject: Reply with quote
Really guy... REALLY?
mkjackary
PostPosted: 14:56 - 28 May 2017    Post subject: Reply with quote
My little sister was concieved, born, and has finished primary school in the time it has taken you to reply to that post.
The last post was made 8 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 60.82 Kb
