What to buy
Bike Chat Forums Index -> The Cycling Forum
Pie-Roe
PostPosted: 19:16 - 12 Aug 2015    Post subject: What to buy Reply with quote
Need a bike to travel 2-3 miles around town most days.
Should I just look at whatever is cheapest? Ideally would be useful to have something I could put panniers on, is that usually a universal rack or whatever?
I know absolutely nothing about pushbikes, I haven't ridden one in about 10 years.
Seb
PostPosted: 21:13 - 12 Aug 2015    Post subject: Reply with quote
Don't bother with suspension, lighter = better. If you're planning on buying second hand be sure to know how to check bearings etc or take someone along who does.
2010 Triumph 1050 Sprint ST
Pigeon
PostPosted: 23:15 - 12 Aug 2015    Post subject: Reply with quote
I would say yes to suspension, but don't get a mountain bike. Way too heavy!!
Get a hybrid, light frame and large skinny rims.
I had a £180 Claud Butler Urban 200. 50mm of suspension travel was tiny but useful. They don't seem to be that cheap now, circa £300.
This looks ok
At this pirce, I'm led to believe that hydraulic disc brakes are not worth the hassle. But mechanical disc brakes (ie cable) are ok. I've got them and they crap all over v-brakes in the wet
That said, you could save £70, get v-brakes instead.
But the forks and chainset are slightly worse.
Both have pannier mounts.
It's still alot of money, but bikes seem to be expensive. Could get something better second hand on ebay. But hassle.
PostPosted: 23:50 - 12 Aug 2015    Post subject: Re: What to buy Reply with quote
Most cheaper bikes should take panniers ok - it's only when you get to more specialised lighter/off road bikes that there's issues.
Personally I'd avoid suspension on a hybrid too - no real need for it unless the pot holes etc are stupidly bad.
Do you have an idea of budget?
As an idea, I recently got a mountain bike setup as a hybrid for £135 ... it came with panniers and racks along with decent road tyres.
Seen a similar set of panniers racks alone sell for £140 in the last year, which made up for the ineffectual suspension (I've now stiffened up to the max so it does as little as possible) and poor cable discs - some can be pretty bad, though not sure if in this case it's cheap pads or just cheap everything.
If you want rack and panniers, definitely worth seeing if you can get a second hand one with them already, can save you a good bit.
Note that mountain bike doesn't have to be heavy and hybrid's are often just as heavy or worse.
The lightest bike I've got is a road bike, then a 6" travel mountain bike, then a hybrid, another couple of mountain bikes, hybrid above, another 6" travel mountain bike.
Pigeon
PostPosted: 00:11 - 13 Aug 2015    Post subject: Re: What to buy Reply with quote
mmmm, my brain must have been switched off. As Seb and G said, no need for suspension.
My route involved a mile of canal towpath, but if you're just on roads, suspension just adds weight and reduces your go-forward.
As you were chaps Smile
DRZ4Hunned
PostPosted: 00:25 - 13 Aug 2015    Post subject: Reply with quote
I got a used Dawes commuter bicycle for £40 on Ebay. Wouldn't bother paying much more for a commuter. I've heard Carrera do some good ones though.
DRZ400-SM
FZS600
PostPosted: 10:31 - 20 Aug 2015    Post subject: Reply with quote
I really wouldn't worry about it being light, it's 2-3 miles that's 10-15 minutes riding tops. I'd buying something heavy to make it harder so I actually get a bit of a workout.
I built a scrappy cheap fixie for sub £40, it looks shit but it well serviced. It goes OK and will NEVER get nicked. I built to to get more of a workout when I go for rides with my missus as I'm a fair bit quicker than her. Being on my Carbon or Steel racer is too easy, on the fixie I get a sweat on.
The last post was made 11 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 53.16 Kb
