Back into biking with a ZRX1100 - What to look for?
moppy
PostPosted: 14:10 - 15 Aug 2015    Post subject: Back into biking with a ZRX1100 - What to look for? Reply with quote
Considering getting back into biking after a couple of years out and have been making the rounds looking for the next bike.
I've found a 98 ZRX1100 within budget, but it lacks any service history (owned by a mechanic Rolling Eyes ) for most of it's life.
The bike looks tidy, but the forks make a strange "woosh" or sighing sound when they're rebounding up, as if there is some air escaping. Any idea what this could be?
Any idea what would be a good price for a stock 98 ZRX1100 in good condition with ~30k miles on it?
Casper
PostPosted: 14:29 - 15 Aug 2015    Post subject: Reply with quote
PM ZRX61. He has had his for years and from new as far as i know. Cracking bikes and if no rattle or smoke i would be paying about £1500-2000 for a 98. If the standard gold rear shocks give a close inspection after a test ride. If leaking when i had mine you could not get them rebuilt. Thanks may have changed now but expensive to replace and never buy Hagon budget ones to put on. They turn a great bike into a heap of jelly shite. Dont ask how i know. Front end could be old fork oil or it just wants a good clean out with the dampers out and washed properly.
moppy
PostPosted: 14:52 - 15 Aug 2015    Post subject: Reply with quote
Message sent!
I did check the shocks after a very short bimble, they didn't seem to be leaking but are the stock ones.
I'm not very mechanically minded, so I'm guessing a dealer would charge £100 or so to have a look at the forks. Would the forks make this kind of noise if they were bent?
Thanks
Casper
PostPosted: 15:24 - 15 Aug 2015    Post subject: Reply with quote
Never ridden a bike with a bent fork mate but i would say you would feel it. It would tuck in to whatever side is bent when braking or it would want to turn. Also i would imagine the chrome would be cracking. The damper inside is a tube full of holes if its only had oil changes over the years then these may be part blocked with old shitty thick out as water does get in when fork seals start to go. As long as it rides in a straight line and you can coast with the hands of the bars straight then dont worry about it as it will be a simple strip and clean with fresh oil and seals.
ZRX61
Victor Meldrew
PostPosted: 21:36 - 15 Aug 2015    Post subject: Reply with quote
Mine doesn't do that, but I've had them apart for new seals at least 4 times (116,000miles).
Finally figured out what was causing the seal issue. There's an over pass on a local freeway that I am prone to using as a take off ramp. To clear the entire over pass you have to hit it doing at least 125 mph or so. Fun if you time it so you are level with a car in the next lane when you achieve orbit. Friend was riding his ZRX two lanes over when I did it one time & it scared the piss out of him. Didn't have his GoPro turned on & now he has Harley he would be too far back to film it..
Mine tracks dead straight at 120mph with my hands off the bars. Only shimmies a bit when the front tire is close to replacement.
My advice is to take it out for a thrash & determine if all is well. They run forever. Haven't even had the clutch cover off mine yet. Currently parked with a leaking radiator (3rd time) Easy fix with Oxy/Acet. They crack in the same place. Cure is to remove the bolts from the upper mounts to allow it to move about a bit (which I keep forgetting to do...).
They're not one night stands, they're auditions.
The last post was made 11 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 45.07 Kb
