Does anyone on here make PCBs?
nowhere.elysium
The Pork Lord
PostPosted: 16:10 - 15 Aug 2015    Post subject: Does anyone on here make PCBs? Reply with quote
I need a small batch done on the cheap, and I'm struggling to get consistent results with that press'n'peel stuff.
Confusion
PostPosted: 16:26 - 15 Aug 2015    Post subject: Reply with quote
Iron-on / toner transfer is great for making prototypes, but as you have
found, the results are not quite up to production standards.
Photographic method is better. You can make the artwork using
acetate film (Staedtler or similar) and a laser printer. For best
results, I print two sheets and stack them for better opacity
of the circuit tracks. I use a standard 500W halogen outdoor
light from B&Q as the UV source for exposing the photo-sensitive
PCB and a weak water/caustic soda solution for developing the boards.
This works well for simple, single-sided boards.
https://homepage.eircom.net/%7Eei9gq/counter-pcb.jpg[/img]
Bandit 650SA, ZZ-R1100
nowhere.elysium
The Pork Lord
PostPosted: 16:30 - 15 Aug 2015    Post subject: Reply with quote
OK. I'd been hoping to avoid the light method, purely because of space constraints and relative tightness of cash. I'll have a look into doing it, but I'm a bit sceptical of buying a bunch of developer and UV lights just for a single use.
I might just practice a bit more with the press'n'peel stuff first, though.
R_Josh
PostPosted: 19:05 - 15 Aug 2015    Post subject: Reply with quote
I don't know if this helps.
2 layer boards are $5 per square inch (with 3 copies of your board included in that price) and ship in under 12 calendar days from ordering.
4 layer boards are $10 per square inch (also including 3 copies of your board), go to the fab once a week, and have a 2 week turn time from the fab.
https://oshpark.com/
Current Bike: Honda CBR 125R R-C SUPER sports (SOLD)
Excuse my brevity
ferrisio
PostPosted: 19:11 - 15 Aug 2015    Post subject: Reply with quote
Haven't done it for ages now, it's so much nicer to do double-sided boards with solder masks and use an online service if you don't mind waiting 7-10 days to get a decent price.
BMW R1100R
c_dug
PostPosted: 19:45 - 15 Aug 2015    Post subject: Reply with quote
I don't deal with electronics stuff so might be barking up the wrong tree, but we have a circuit board milling machine at work if that's any good to you?
Im-a-Ridah
PostPosted: 20:58 - 15 Aug 2015    Post subject: Reply with quote
Etching is ok for clumsy big circuits. Small stuff they can done very well but getting it right verges on impossible as the timing, strength and temperature have to be well controlled. Ferric chloride is terrible at staining things, and those things in turn can quite happily stain other things, and you won't be getting it out. Milling avoids these problems but replaces it in the case of small circuits with depth control of fine cutters which snap easily.
c_dug
PostPosted: 21:05 - 15 Aug 2015    Post subject: Reply with quote
Confused I'm so lost in The Geek Zone, it's like you all speak a different language Laughing
I have no idea what Mr Ridah actually said, but if that makes the milling machine any use I can probably sign you in one weekend and you can work your genius magic on it, or I can speak to our department resident circuit genius and he can tell me what files it runs on. Or something.
I'm honestly lost with this stuff
ScaredyCat
PostPosted: 22:39 - 15 Aug 2015    Post subject: Reply with quote
You work at the Science museum - it's easy to get distracted ...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Im-a-Ridah
PostPosted: 16:53 - 16 Aug 2015    Post subject: Reply with quote
I wrote that post after getting back from the Science museum in London Laughing
WD Forte
PostPosted: 19:01 - 17 Aug 2015    Post subject: Reply with quote
How many, what size and complexity?
I made this single sided board for an Atmel 328 uC ( Arduino )
using .9mm drill and vee bit from a vector/dxf file.
I've made smaller ones for my Home, brew flasher units and stuff
and more of an enthusiastic amateur than expert
https://oi60.tinypic.com/2j2zuio.jpg
bikers smell of wee
The last post was made 11 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 70.61 Kb
