Marauder 125cc 51 plate front cluster problem
bulldog1965
PostPosted: 11:52 - 17 Aug 2015    Post subject: Marauder 125cc 51 plate front cluster problem Reply with quote
Hi Hello im new to the BCF but im glad im here.
My question is i have just bought a marauder GZ Y 125 cc on a 51 plate and after a day the bulbs went on front cluster panel showing the indicator and ignition lights. I changed the bulbs on both but there still not working. Is there anything I can do to find out what's wrong and fix it. I've just passed my CBT and have a problem not seeing the indicators are on or off .. I have thought I had turned off my lights but many drivers have flagged me telling me there still on. This wouldn't of happened if i could see the indicator light still illuminating.Help needed please I'm new to bikes as you can tell.
Andy_Pagin
PostPosted: 12:01 - 17 Aug 2015    Post subject: Reply with quote
Unless they're on a seperate fuse from the rest of the electrics, which I doubt on a 125, your only option is to trace back through the loom looking for any loose, corroded or broken connections. My guess would be a didconnected earth wire.
bulldog1965
PostPosted: 18:09 - 17 Aug 2015    Post subject: Reply with quote
Andy_Pagin wrote:
Unless they're on a separate fuse from the rest of the electrics, which I doubt on a 125, your only option is to trace back through the loom looking for any loose, corroded or broken connections. My guess would be a did connected earth wire.
Cheers Andy!
Its a bit of a bummer having just bought it to start playing around with it but hay ho that's life. I'm on it tomorrow in the garage I noticed the chain is very tight and on it last notch of the adjuster so ordered a new chain and sprocket set and fork seals as one side has a leak so its gunna be fun and allot of you-tubing videos. Looks like hardest thing is chasing the fault back for the dash lights. Thanks allot mate looks like a good community on here.
alekc
PostPosted: 14:14 - 18 Aug 2015    Post subject: Reply with quote
For the electric issue I would suggest to purchase multimeter (i.e. something cheap like https://www.ebay.co.uk/itm/DIGITAL-LCD-VOLTMETER-MULTIMETER-CIRCUIT-TESTER-AMMETER-AC-DC-METER-OHM-YELLOW-/141093479832?hash=item20d9d3a598)
It will help you to understand if there is a tension at all in wires and if from one end of wire to another there is a stable link.
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 10 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.88 - MySQL Queries: 13 - Page Size: 49.62 Kb
