Chain Tension on Dirtbike.
Gazz
PostPosted: 22:02 - 07 Aug 2015    Post subject: Chain Tension on Dirtbike. Reply with quote
Something has puzzled me, I just got an MOT the other day and I got an advisory for the chain been too LOOSE!!! However, prior to this I had the bike in for and MOT elsewhere and the tester said that the chain was too TIGHT!
The only thing that I can think of is that due to the big amount of suspension travel, giving these 2 different MOT testers different results when they checked the bike. Possible?
Am I correct in saying that you should check chain tension with someone sitting on the bike? And if so, would they do this at an MOT station?
I have searched online and cannot seem to find the correct tension for my bike Hyosung XRX 125 so I used a the 3 finger technique. (There are quite a few posts about this technique online).
However, I don't know if this is right on not, because despite being a dirtbike the XRX is pretty much a road bike, the rear sprocket is fairly small, etc and is geared for high-ish speeds compared to an outride dirtbike with massive sprocket on the back. Would this have any impact on the chain tension?
PostPosted: 22:51 - 07 Aug 2015    Post subject: Re: Chain Tension on Dirtbike. Reply with quote
Chain tension will vary with suspension movement. So with more movement (also length of swinging arm, position of front sprocket to the swinging arm, etc) you need a different amount of tension.
But if you sit on the bike then the swinging arm is in a fairly random position depending on how much you weigh, and hence how it has affected chain tension is pretty random.
Workshop manuals if they specify it that I have seen list it without sitting on the bike.
K
stuartt
PostPosted: 21:34 - 14 Aug 2015    Post subject: Reply with quote
my busa is about 30 mm & my gas gas is about 60 mm , if the chain on my gas gas can touch the top of the swinging arm i tighten it a little bit .
PostPosted: 21:46 - 14 Aug 2015    Post subject: Reply with quote
What does the Manuel say?
Suntan Sid
PostPosted: 21:35 - 17 Aug 2015    Post subject: Reply with quote
The manual for my Honda XL125 says 25mm!
thx1138
PostPosted: 22:41 - 17 Aug 2015    Post subject: Reply with quote
https://lifeafterbread.co.uk/wp-content/uploads/2012/08/que.jpg
The last post was made 11 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 49.14 Kb
