MOT pillion pegs
chrisjose1913
PostPosted: 00:41 - 19 Aug 2015    Post subject: MOT pillion pegs Reply with quote
Hello I have a honda clr 125 (city fly) it's going in for an mot soon, sadly it's missing the rear pegs and hangers. i have read you can simply take out the rear seat and convert it to a single seat bike for it to pass the would help if my bike had to seats Sad. In my case the seat is all in one so removing the rear seat cannot be done without removing the seat all together, the bike is being converted to a dual sorting bike, any suggestions ? Thumbs Up
1997 CB500
SQL
PostPosted: 03:32 - 19 Aug 2015    Post subject: Reply with quote
duct tape a box to it, its now single seat
PostPosted: 17:07 - 19 Aug 2015    Post subject: Reply with quote
Fit a long bolt through the upper hanger mounting bracket with a bit of rubber hose slipped over it to cover any sharp edges/points.
Nothing says they have to be either comfortable or sensibly positioned, they just have to be present, securely attached and possible to get your feet on from the pillion position. Otherwise many sports bikes would fail with their little foam pad for a seat and knees under your chin footpegs.
An M8 spout bolt mounted head-out the way with a bit of 8mm ID rubber hose slipped over it and attached to the hanger bracket by a nuts either side looks pretty much meant. I've used this before.
PostPosted: 17:10 - 19 Aug 2015    Post subject: Reply with quote
Vincent wrote:
Did you really, genuinely just suggest drilling a hole in the swingarm? Confused Shocked
Hard to tell if that was a deliberate troll.
OP, do not drill holes in your swingarm. Swingarm-mounted pillion pegs were actually a thing back in the 70's, and yes, your feet do go up and down over bumps BUT they were mounted on a bracket welded to the swingarm, not bolted through.
chrisjose1913
PostPosted: 00:04 - 20 Aug 2015    Post subject: Reply with quote
Thanks for the advice, I have come up with a solution, I have ordered universal bolt on pillion pegs, I will mount them to the holes the hangers would have been bolted in. Thumbs Up
1997 CB500
delsol
PostPosted: 07:44 - 20 Aug 2015    Post subject: Reply with quote
Vincent wrote:
For someone who obviously knows a bit about spannering.
Tut Tut
Don't mess with structural members, leave that to somebody qualified in structural integrity, like MrGs1 (he's a bricky you know).
PostPosted: 09:39 - 20 Aug 2015    Post subject: Reply with quote
Vincent wrote:
but drilling a hole into a box section arm doesn't weaken it.......unless the hole is 40mm or similar of course.
So wheree's the cut-off?
You assert a 40mm hole WOULD affect the structural integrity of the swingarm but a 10mm hole would not. What about a 20mm hole? Or a 30mm hole? Or a 39mm?
Then we get down the WHERE on the swingarm this hole is. Having installed bits and pieces of wiring/plumbing, you can safely drill quite a large hole through the centre of a joist because the stress and strain is borne by the very top and bottom of the joist. However, there are fairly strict guidelines for how large and how close together these holes can be which get more strict the further you get from a supported end.
So. We mutually accept that while you probably can drill a hole of some sort in a swingarm without drastically altering its structural integrity, there comes a point where that hole is so big it DOES and neither of us know what that point is.
I further assert that the likleyhood of structural failure increases, the further from a supported end you get. Because engineering.
There is a third point. A hole through a rectangular member will have a relatively small effect on integrity in the plane perpindicular to the hole. It will however have a much larger effect on the plane paralell to the hole. So a hole through the side probably wont have much effect on the vertical stiffness but it could compromise horizontal integrity.
Given we have three variables determining the likleyhood of a hole in the swingarm affecting structural integrity (size, distance from end and relative position) which neither of us appear to have the engineering knowledge to evaluate, your advice was bad. I can't definatively say it's unsafe any more than you can say it's safe.
I assert, with some basic engineering knowledge (obtained many years ago during my higher technology course which did cover stress/strain relationships, youngs modulous etc), that drilling a hole in a motorcycle swingarm to mount pillion footpegs may well be unsafe.
Shinigami
PostPosted: 19:38 - 20 Aug 2015    Post subject: Reply with quote
...yeah even I wouldn't drill a hole in a swing arm and i'm a bodge monkey
The last post was made 10 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 77.38 Kb
