50cc tgb 101r new piston new cylinder and wont start
gauka
PostPosted: 19:27 - 18 Aug 2015    Post subject: 50cc tgb 101r new piston new cylinder and wont start Reply with quote
hi there i need help
i have replaced crankshaft, new cylinder and also new piston
inject the petrol under the spark plug and the bu.... still wont start
the exhaust been taken off , have no idea what that could be
compression around 97 - according to manual is ok
thanks for suggestions
Regards
Lukas
skyebiker
PostPosted: 22:41 - 18 Aug 2015    Post subject: Reply with quote
have you checked your getting a spark from the spark plug ?, also something i learned is make sure the stand isen't on or you won't get a spark what so ever
gauka
PostPosted: 22:48 - 18 Aug 2015    Post subject: Reply with quote
It has spark well don't know if is good enough is blue but not fat I would say, that's my problem, I wonder if is cdi unit I also have noticed there is a marking line and dot on fly well that I can't match up is that matter or is for torque ?
skyebiker
PostPosted: 00:31 - 19 Aug 2015    Post subject: Reply with quote
it could be but i don't know how to do the timing on a bike only a car. see if youtube can show you how to do timing, if your getting spark, and your getting fuel, and its timed up correctly it should fire as the CDI box tells the spark plug when to fire but if your timing is out then it will be sparking at the wrong time
gauka
PostPosted: 00:43 - 19 Aug 2015    Post subject: Reply with quote
I will do thank you
Robby
Dirty Old Man
PostPosted: 14:37 - 19 Aug 2015    Post subject: Reply with quote
I assume this is some kind of cheap far eastern scooter. I also assume it is a 2 stroke.
You have a spark. Assuming a CDI type set-up, it's hard to get the ignition timing wrong, and the fact that you have a spark means all of the bits fo ignition are there. We can ignore spark for now.
You mentioned the exhaust being removed. Don't try to start an engine before putting it all together. Put the exhaust back on.
At this point you should have an engine that is bolted together, compression, and a spark. The only thing left is fuel/air, in the correct ratio.
Make sure you have fuel to the carb. Make sure the carb is clean internally and set to standard factory settings. If the 2 stroke oil line hooks into the carb, make sure it is hooked in and has oil in.
Now crank it until it starts.
gauka
PostPosted: 15:22 - 19 Aug 2015    Post subject: Reply with quote
hi thanks for reply
i have had all put back together before and did not start.
so i have taken every think apart and put together one more time in
case i forgot to do something, however i have not noticed anything.
it is far east scooter and it is 2 stroke engine so is simple like a Lego
well scooter have started after 10 min of cranking for 3 sek and the
engine was hot but that all i cant start him anymore ;(
The last post was made 10 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 50.16 Kb
