kdx n kmx 125
2strokestroke...
PostPosted: 21:00 - 19 Aug 2015    Post subject: kdx n kmx 125 Reply with quote
Hi I'm restomoding both a Kdx125 n Kmx 125 we kKdxmore enduro n kmx supermoto n need info,1 what yr kx is Kdx based on? Its 92 model we rwu forks (for now), do I need a press to replace main bearings? What yr kx USD forks fit if any? Pref 250 forks coz I'm heavy,will a Kdx 200 top end go on or is they a kx barrel that will? Know about ring intervals n stuff if do this, is rear shock re buildable or what kx in will go? Kx exhaust? I know could buy kx but wanted a Kdx when new n had prob 5 kmxs so.... Anyone with a kmx200 barrel n head?pref knackered coz be wantin put steel sleeve in anyway n got couple kmx 125 top ends to trade if helps 1 nikasil original n 1 we steel sleeve, I'm derbys , same if anyone got suitable front ends etc? No silly prices
weasley
PostPosted: 22:40 - 19 Aug 2015    Post subject: Reply with quote
The KDX125 barrel is unique to the KDX as it does not have a mount for the carb, since this is mounted on the crankcase. All the others mount the carb on the barrel. KDX barrels are tough to find (I had to find two!).
Mine had a USD fork (with two piston brake caliper) which I never identified, although I believe it was a KDX 200 front end. Dangerousdave on here knows his stuff on these things.
stevo as b4
PostPosted: 00:20 - 20 Aug 2015    Post subject: Reply with quote
Good luck getting any KMX200 top end parts for non silly prices. if anyone does have them I doubt they will let them go now if they might need them, and often they are not cheap. It's looking like getting a complete bike is the best way to get your hands on a motor or just parts from it.
The KDX125 I think was based on the 88-89 KX125. The cylinder from the KX might well go onto the cases, but you will need to research this yourself and look up parts numbers etc. It's worth comparing gaskets from KDX and KX's on parts diagrams to see what is common or looks the same. The trouble is finding a decent used 88/89 KX125 cylinder will be harder than even KMX200 bits. I don't think the barrel alone will help you much, as for it to run well you'd need the KX head, Carb, exhaust and probably the ignition or at least the correct advance curve to suit. You definitely won't find a decent KX125 pipe knocking about unless you are prepared to buy new or custom made.
Id personally either forget trying to combine KX and KDX parts and just tune the KDX engine if you want to, or try and fit a KDX200SR engine into the chassis instead.
weasley
PostPosted: 07:18 - 20 Aug 2015    Post subject: Reply with quote
I looked at KX barrels when trying to find a KDX one. As I said, the KX has the carb on the barrel so is totally different. You may be able to make it work, but it's not a bolt-on solution.
I may even have a couple of wrecked KDX barrels somewhere, but they will need sleeves.
2strokestroke...
PostPosted: 14:38 - 20 Aug 2015    Post subject: Reply with quote
Thanks on offer of Kdx barrel iv got 1 we steel sleeve in but yea... Thanks I'll bear in mind, a USD front end s what also need?? Really appreciate reply tho
stevo as b4
PostPosted: 17:44 - 20 Aug 2015    Post subject: Reply with quote
88> KX125's and all KDX125's use a crank case reed inlet set up. It's the KMX125/200 and KDX200/220/250 that have cylinder mounted reed induction system.
Id say unless your lucky you would need to modify a KDX125 head or use a KX125 head to fit a KX125 cylinder and piston. You must use the correct piston for the model as all the cut outs and windows will be different between KDX and KX models.
I'm not sure what the inlet manifold and reed block looks like on the KDX125's being case reed KX derived engines, but with the KMX/KDX200/220 all the reed blocks from each model fit the other's as do the manifolds allowing you to fit different size carbs etc.[/list]
dangerousdave
PostPosted: 19:37 - 20 Aug 2015    Post subject: Re: kdx n kmx 125 Reply with quote
No, you don't. Its the big-end bearing which is a specialist job, if you don't know what you're doing get a shop to do it.
None are a bolt on replacement. You can take pretty much any year of KX/KXF forks as long as you get the correct size bearings. Given a choice, try and get KXF forks as they are more advanced than earlier versions.[/quote]
Neither will bolt on. I've never heard of anybody making either work.
KX is every 15 hours for piston and rings I believe. KDX200, fix it when its broke, is a real trouper in comparison.
Shocks can be rebuilt;t, but they are not made to be disassembled, like most OEM shocks. Its the anti-tamper mechanisms, and lack of spares available which makes these more difficult than aftermarket shocks.
No KX shock will go straight in. Have seen a KX shock fitted, but this requires a KX swingers, linkage, and rewarding the top shock mount to the frame as this is totally different on the KX. Saw somebody fit a KTM shock to a KMX125, but with mixed results, and not a clue of what year shock fitted and if any mods were necessary.
Kx exhaust?
Doesn't fit KMX or KDX, they use a spring mounted manifold at the cylinder. The KMX KDX bolts on. Thats the first hurdle. Then fitments to the frame etc.
The main point though is unless you are running a KX engine, then a KX exhaust will do nothing good to the power delvery of a KMX or KDX. They are totally different engines, which need very different exhaust shapes to do their thang.
Ok, maybe keep the KDX in standard trim them. They are great bikes. Or else buy a KX.
Ok nice.
Pretty rare now as said, I have some spares but holding on to them as don't know when would find another.
There's a guy selling sleeved ones with Mitaka pistons and gasket on feebay for 380 quid from Phillipines.
If thats too much keep trawling the bay, they come up eventually
Most people doing the same as you, wanting to go from 125 to 200. You could flog them and put the money towards a 200 cylinder.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
The last post was made 11 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 57.93 Kb
