b1h fuel tank vent
robertw95
PostPosted: 16:58 - 20 Aug 2015    Post subject: b1h fuel tank vent Reply with quote
Ok so my trackbike has a problem with the tank vent.There is a vacuum being built up inside tank causing fuel not to go through leaving me with a huge flatspot and surging. I replaced the cap with a quick release race one hoping it was just the originals breather hole blocked. When I started the bike and let it get up to temp before turning off and taking cap off there is still the whoosh of air going inside.
There is no external vent tube to check etc so I'm guessing I need to get the fuel pump out... anyone know of anything I may have missed? Cheers
07 Dt125r, sv650s k8, zx6rr 04
monkeybiker
PostPosted: 17:46 - 20 Aug 2015    Post subject: Reply with quote
Does it use the overflow pipe as the breather? My bike is designed like that. Check the tube is not blocked or kinked.
robertw95
PostPosted: 17:54 - 20 Aug 2015    Post subject: Reply with quote
I can blow through breather pipe fine no kinks, I had pump off to check for blockages before putting it back on, there is what looks like a pipe inside but wasn't connected to pump ... at a loss here definitely still a vacuum being formed inside tank but the cap I fitted has a small hole I assume is the breather
PostPosted: 17:55 - 20 Aug 2015    Post subject: Reply with quote
Put the old cap back on sounds like a crap cap.
robertw95
PostPosted: 18:10 - 20 Aug 2015    Post subject: Reply with quote
It was happening with standard which is why I changed, its a track bike and this cap was recommended by a friend
PostPosted: 18:46 - 20 Aug 2015    Post subject: Reply with quote
Fair enough, in that case have a go at clearing all the breathers I use guitar strings Thumbs Up
robertw95
PostPosted: 18:50 - 20 Aug 2015    Post subject: Reply with quote
Problem is the only tube coming from the tank is an overflow which is clear, From what I could see when I had the pump out there is a pipe inside the tank which I believe is the vent that is blocked, just no idea where it goes to or if its connected to pump etc
robertw95
PostPosted: 19:49 - 20 Aug 2015    Post subject: Reply with quote
Removed one of the seals from cap that appeared to cover breather hole, no more rushing of air Laughing
The last post was made 10 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 54.22 Kb
