I have a massive screw in my rear tyre
RedPanda
PostPosted: 18:29 - 27 Aug 2015    Post subject: I have a massive screw in my rear tyre Reply with quote
https://img.photobucket.com/albums/v624/philr46/ARGH_zpsuyafi71j.jpg
4 months after a c*** builder couldn't be arsed doing up his toolbox so my 125 needed a new tyre, I've gotten home and seen this in my rear.
Should I leave it in and try tiptoe to a tyre shop in the morning? The closest is about 3 miles away. Does that look pluggable?
This is a total, total ballache as I need it for long-ish distances on Saturday and Sunday. Bollocks!
CBF125 (2013) -> CBR600F (2001) -> 'Ninja' 300 (2014)
PostPosted: 18:40 - 27 Aug 2015    Post subject: Reply with quote
It doesn't look pluggable. Not completely through and weird entry angle is behind my reasoning
If you've got use of a car take the wheel off and save yourself some quids and reduce the worry.
pompousporcup...
PostPosted: 18:42 - 27 Aug 2015    Post subject: Reply with quote
Tip toe to nearest tyre person if it's still holding air
Imo I wouldn't bother plugging it due to the way the screw is in.. it may not have penetrated the ply yet but would no doubt be asking for trouble/stranded. Judy my 2p though
RedPanda
PostPosted: 19:20 - 27 Aug 2015    Post subject: Reply with quote
Thanks. I don't drive but my dad could maybe come and collect it and take it to a tyre fitter. Hopefully it'll be okay to ride in the morning and they can plug it or have the correct size tyre in stock.
I have Pirelli Diablos with lots of life in them, so lots of money down the pan.
PostPosted: 21:11 - 27 Aug 2015    Post subject: Reply with quote
Aw damn, that is a nasty one. Sad
Regardless of the outcome, I'd suggest that you get a tyre plugging kit for future use. I recommend the Stop-And-Go kits with the little mushroom plugs. Even if you didn't manage to plug that you could at least have a go and know one way or the other whether it's had it.
mentalboy
PostPosted: 21:48 - 27 Aug 2015    Post subject: Reply with quote
Go on then, show us a pic of the tyre with a little more tread visible. Either that isn't such a big screw and a macro shot OR you are running on slicks!
(EDIT: Or Supercorsa's Embarassed )
Hard to tell without knowing how deep into the tread it's gone, is that about an inch of screw buried in there? As others have said it'll be a bar-steward to plug, especially if it hasn't actually breached the tyre.
RedPanda
PostPosted: 22:35 - 27 Aug 2015    Post subject: Reply with quote
2-2.5cm, going sort of along the surface rather than straight down.
https://i57.tinypic.com/scz981.jpg
Yes they are fairly slick so in a way it may be a blessing as I can get a more winter friendly tyre. It's still quite hard and inflated so fingers crossed for 9 hours' time.
Raffles
PostPosted: 23:03 - 27 Aug 2015    Post subject: Reply with quote
Difficult to give a definitive answer but that screw doesn't appear to have penetrated deeply. If the tyre has 'lots of life' left in it then you may just get away with leaving well alone.
If you take it to a tyre fitter they will most likely yank it out with a pair of pliers and thus probably cause irreparable damage.
I would be tempted to unscrew the screw from the tyre and continue to ride as normal.
binge
Emo Kiddy
PostPosted: 23:08 - 27 Aug 2015    Post subject: Reply with quote
Get yourself to me tomorrow and I will repair that for you. Thumbs Up
ME8 8AX
kramdra
PostPosted: 23:10 - 27 Aug 2015    Post subject: Reply with quote
I would do a lot of things but there is no way I would ride on that. Do you know how thin (..the important, corded part of..) a tire is? it is very easily damaged if objects do not go straight in
Tires flex, and the screw head, that is going to do maximum possible damage each revolution.. threaded section cutting into cords...very likely to rip out of fail in the first mile.
I would remove screw and put a temporary plug in if I really had to - it would hold air, but would be very cautious if the structure is going to last a couple miles at slow speed. Plugs are very cheap and at slow speed ~20mph its not going to do any damage when it fails.
Better option - ebay a new tire or some scrubs and the few tools needed and fit yourself. It is a very quick, easy task and will pay for itself on first attempt.
andyscooter
PostPosted: 07:35 - 28 Aug 2015    Post subject: Reply with quote
needs the bike tomorrow so cant ebay it as needs it NOOOWWWW
I would ride on it to get it repaired/changed
RedPanda
PostPosted: 09:55 - 28 Aug 2015    Post subject: Reply with quote
Andyscooter, Sharpe and Bodyguard win as I rode it there without it deflating, then they removed the screw and said it hadn't gone beyond the surface, so no plug or charge either. I will still be very careful and will check my tyre pressures later, but it looks like it could have been a lot worse Thumbs Up
PostPosted: 10:02 - 28 Aug 2015    Post subject: Reply with quote
I'd have unscrewed it... see if it held air. Then forgotten about it.
The last post was made 11 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 81.97 Kb
