10v NSR wire
AdamBoyle
PostPosted: 19:40 - 06 Feb 2005    Post subject: 10v NSR wire Reply with quote
Evening!
Hope you're all ok. Ive spent the last 30 minutes of my sunday playing with my cheetah alarm. Although ive had a lot of help from the guy that sold it (wiring diagram specific to my bike, the lot) i still cant get the thing to work properly. I think have the problem is the purple/
white ACC wire which needs to be connected to a wire that is +10 volts when the ignition is on, and nothing when the ignition is off.
Is anybody here an old hand with bike electrics, or has anyone fitted one of these alarms to an NSR125R successfully?
Thanks guys - Thumbs Up
Bike - Honda NSR125R1 (Sold)
Passed Theory: 20/12/2007
Passed Practical Test: 10/03/2008
sickpup
Old Timer
PostPosted: 20:22 - 06 Feb 2005    Post subject: Reply with quote
+ side rear brake light switch.
AdamBoyle
PostPosted: 22:22 - 06 Feb 2005    Post subject: Reply with quote
Already tried connecting through the rear break feed, but i dont think it carries enough power. Always worth another go though...
sickpup
Old Timer
PostPosted: 22:30 - 06 Feb 2005    Post subject: Reply with quote
It carries whatever voltage the battery carries. You did have it on the + side didn't you?
AdamBoyle
PostPosted: 10:24 - 07 Feb 2005    Post subject: Reply with quote
There are 3 wires running to each of the rear lights (so 6 in total...)-I checked the voltage carried across the brown one (which i assume i live) - Will have another go at it when i get home today..
sickpup
Old Timer
PostPosted: 11:48 - 07 Feb 2005    Post subject: Reply with quote
I didn't say rear lights I said rear brake light switch.
The rear lights won't have a permanent supply unless they are hardwired in the on position unlike the brake circuit that does.
AdamBoyle
PostPosted: 16:07 - 07 Feb 2005    Post subject: Reply with quote
Rear break light switch being the foot brake pedal?
sickpup
Old Timer
PostPosted: 17:57 - 07 Feb 2005    Post subject: Reply with quote
Yep. The pedal will be connected to a spring which connects to a pull switch with two wires coming out of it. Trace these wires back to the single box or two bullet connectors and find the positive. Connect to the positive on the loom side of the connector.
The last post was made 21 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 57 Kb
