No tail light?
Saltire
PostPosted: 19:22 - 31 Aug 2015    Post subject: No tail light? Reply with quote
Having more issues with my belter of a bike.
Brake light works fine but no tail light, any points on the bike you guys can suggest I check before I take it back to the garage it spends most of it's time in?
Lexmoto Lowride but doubt knowing the make helps since you don't get manuals for these buggers.
monkeybiker
PostPosted: 19:44 - 31 Aug 2015    Post subject: Reply with quote
Try changing the bulb.
PostPosted: 19:48 - 31 Aug 2015    Post subject: Reply with quote
+1, the bulb has 2 filaments, one is probably blow.
Saltire
PostPosted: 19:52 - 31 Aug 2015    Post subject: Reply with quote
Nope. First thing I did.
PostPosted: 20:13 - 31 Aug 2015    Post subject: Reply with quote
Other than giving the wiring harness a jiggle at various points, all I can say is that buying a £5 multimeter will save you a lot of time and guesswork.
What dealer, out of interest?
Michelle L
PostPosted: 09:24 - 01 Sep 2015    Post subject: Reply with quote
I would still buy a new bulb to try it , how much are they a few sqid..
It might look ok but It may be faulty..
I would always go for the cheaper option first ,, you might be lucky..
Hope its an easy fix Smile .
Ride safe , if you can not ride safe , ride free....
RhynoCZ
PostPosted: 11:38 - 01 Sep 2015    Post subject: Reply with quote
OR, do the day time MOT and give up. Dance!
Anyway, there should be 3 wires to the bulb, check them all.
sickpup
Old Timer
PostPosted: 12:17 - 01 Sep 2015    Post subject: Reply with quote
Check the fuse, then check the live to the rear light.
Raffles
PostPosted: 12:22 - 01 Sep 2015    Post subject: Reply with quote
Check for corrosion on the bulb holder contacts.
gibbzy2k1
PostPosted: 07:41 - 08 Oct 2015    Post subject: Reply with quote
Did this get sorted?
I have a similar issue with my street 125. But i know that it is a dodgy connection. The rear light is linked to the light on the clocks, so i can tell if the rear light is out as the clocks down like up. This is intermittent and happens when the handle bars are turned. A good jiggle of the clocks and or the wires passing the handle bars to the clocks lights it back up again.
It usually goes out when the handle bars are turned to the right, and comes back on when turned left. Turning right stretches the wires. I think this is the issue, I pulled some slack out to the handle bars this morning and the lights stayed on all the way to work. So i have some wok to do to clean them up I think.
You probably sorted it by now but though this might help.
The last post was made 10 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 63.11 Kb
