Is a carb balance the same as a rejet?
Silver_Fox
PostPosted: 11:57 - 01 Sep 2015    Post subject: Is a carb balance the same as a rejet? Reply with quote
My new steed has an aftermarket can on the back. The previous owner had the carbs balanced, and said it transformed the bike. Is that the same as having a rejet after fitting a new pipe?
Itchy
PostPosted: 12:03 - 01 Sep 2015    Post subject: Reply with quote
No.
PostPosted: 12:23 - 01 Sep 2015    Post subject: Reply with quote
No... Why would that be the same thing? A carb balance makes sure all four carbs are synchronised so that they give the same air and fuel for a given throttle opening. A rejet changes the size of the jets inside the carbs so that the fuelling is matched to the other changes made to the bike.
c_dug
PostPosted: 12:33 - 01 Sep 2015    Post subject: Reply with quote
You'd probably find that if the jets were changed they'd balance the carbs as part of the same work, but you couldn't make the same assumption the other way.
In other words the bike may still potentially be running lean.
Silver_Fox
PostPosted: 13:02 - 01 Sep 2015    Post subject: Reply with quote
Thank you. I thought it was different (but as I'm new to biking and Googling didn't give me a clear answer) I thought it best to check. Any idea on prices for such a job?
MCN
PostPosted: 13:38 - 01 Sep 2015    Post subject: Reply with quote
The new can can Smile affect how air flows through the engine and that can affect the operation of the carburettors.
To accommodate a different can different jets may be fitted. (But adjustment of the carbs can sometimes manage this.)
If new jets were fitted then the carbs would need to be balanced.
Multi-Cylinder engines can suffer from fuel-ing problems due to the way air is routed to the cylinders. Cylinders further from the carb get less fuel. To rule this leaning out the mixture is enriched. But that means the nearer cylinders run rich. It is a compromise.
To rule out this effect and improve performance, each cylinder can be fitted with it's own carb. (Due to cost/technology constraints, some engines use one carb between two cylinder and etc.)
As each cylinder has it's own carburettor they all have to provide the same amount of fuel for each cylinder to provide a 'balance' of power. If not balanced properly the engine can run 'lumpy' (unevenly), run rich/lean on one or more cylinders among other issues.
You can buy balance gauges and tune the carbs yourself or let a shop do it. The main cost for this is labour to remove/refit the tank and air-filter-box to gain access to the carbs though. 2 hours labour at a guess. But they shop may operate a fixed price for this as it's a fairly common task.
You may have to check balance at each yearly service as it can change if there has been any dirt through the fuel system. Or general wear on linkages. So you might decide to buy the kit and become an expert. It's not rocket surgery.
Silver_Fox
PostPosted: 14:05 - 01 Sep 2015    Post subject: Reply with quote
Thanks. I'd seen posts suggesting try it and many suggesting to leave it to the professionals. I'm getting 53.9mpg which strikes me as a bit much Laughing
MCN
PostPosted: 14:16 - 01 Sep 2015    Post subject: Reply with quote
54/gal is no bad for a multi-cyl. bike. Thumbs Up
I get about 55 on a K1300 in Loony mode and up to 65 in Anorak Mode.
Or 25/gal on my 1000 Track bike in Mental Case mode.
I don't get too analized over bike MPG. Mine are hobby-horses though. I look at it but as long as they can blast from A 2 B via C reasonably quickly it's fine
Silver_Fox
PostPosted: 14:18 - 01 Sep 2015    Post subject: Reply with quote
You know what it's like. Buy a new (first) bike and want to make sure it's running as well as it can
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 15:50 - 01 Sep 2015    Post subject: Reply with quote
Bike is a 1997 CBR600 F3, yes?
Cost is what the local dyno/tuning place wants to charge. I'd want to get an analysis run first before committing to stripping it down and re-jetting.
Plastics to remove, 4 carbs, 18 year old rubbers, could ramp up sharpish.
Silver_Fox
PostPosted: 16:04 - 01 Sep 2015    Post subject: Reply with quote
Yes indeedy. Sounds like the most sensible idea is to remove a spark plug and check the colour first
PostPosted: 17:57 - 01 Sep 2015    Post subject: Reply with quote
If it has just had an end can it will probably be fine.
A lot of the worries/panic stems from the effect playing around with an exhaust has on the strokers, it's not usually a problem on 4 strokes until you change the whole system for something racing.
Triumph Trophy Launch Edition
Silver_Fox
PostPosted: 09:05 - 02 Sep 2015    Post subject: Reply with quote
It does have stainless downpipes too, but I'm unsure if they're anything more than a direct replacement as I can't see branding on them
MCN
PostPosted: 10:02 - 02 Sep 2015    Post subject: Reply with quote
What the bear is alluding to is the loss of restriction to airflow provided by a muffler/silencer.
In some 'set-ups' the muffler is removed. If there's no muffler then for sure some modification will be required for fueling. As it will effect the Volumetric Efficiency Smile. (How air flows through an engine.)
The whole system (air inlet combustion space and exhaust affects) this. As mentioned the exhaust has a much more important effect on two-stroke engines as they have no valves and rely on exhaust back-pressure (restriction in the exhaust) to help seal the exhaust port during the combustion process 'Sook, Squeeze, Bang, Blow'.
Mufflers work mainly be re-directing the energy (sound energy) in the exhaust gas onto parts of the muffler. This decreases some of the sound energy either by cancelling it out (by re-directing it into the escaping gas) and/or absorbing the energy into the construction of the muffler.
All of that creates restriction and the designer tunes the fuel system to suit that 'specific' restriction.
If you 'drastically' alter that then it can upset the fuel settings.
An end can normally won't change much apart from aesthetics.
This is a system to fit a BMW S1000RR.
In a 'Full System' the manufacturer's metal is removed and the fueling controlled using an after-market fuel management device.
Austin Racing BMW S1000RR
Finished Article
janner_10
PostPosted: 21:32 - 02 Sep 2015    Post subject: Reply with quote
I think you're fretting over nothing.
Ariel Badger
PostPosted: 23:55 - 02 Sep 2015    Post subject: Reply with quote
The last post was made 10 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 96.04 Kb
