| Marclev |
 Marclev Nova Slayer
 Posted: 12:51 - 03 Sep 2015 Post subject: Why not park in gear? |
Hi forum,
So during my CBT and DAS training I had it drilled into me that the proper parking procedure was to stop, put bike in neutral, then switch off with the key and put the bike on its stand.
Now that I've got my own bike, this makes very little sense to me though, and I typically just park by pulling up in first, and then flicking the side stand down to stop the engine while holding the clutch lever in (and then start her up in gear later). This way I know there's no chance of the bike rolling anywhere, either while parked or when I later mount it to take off again, and no chance of forgetting to put the side stand down leading to an embarrassing slow drop.
Question is, I'm assuming there's a reason I was tought to always park in neutral, is this a case of giving beginners a set routine to follow, or is there more to it?
Cheers,
M. |
| weasley |
 weasley World Chat Champion
| DrDonnyBrago |
| doggone |
 doggone World Chat Champion
| mauzo |
 mauzo Nova Slayer
| JP7 |
 JP7 World Chat Champion
| dydey90 |
 dydey90 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:01 - 03 Sep 2015 Post subject: |
Depends on the bike and the circumstances.
Nazi Tractor: sidestand cut out switch, gear indicator, reliable neutral sensor = pretty much impossibru to start it in gear with the clutch out. I quite often stop it by swinging the stand down, which tests that the cut-out is working if nothing else.
Enfield: has a cut out switch but it's disconnected deliberately to allow starting with the stand down, because of reasons. The kick starter only engages with the clutch out, and if I can kick it over while its in gear then I'll be astonished at my awesomeness.
GPZ500S: stopped to take a picture for a BCF bike challenge, didn't put it in gear. Picture was of a 10% gradient sign. Facing downhill. Hilarity ensured, for the passing traffic at least.
tl;dr version - it's your bike, make your own decision. ____________________ Biking is 1/20th as dangerous as horse riding.
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Triton Thrasher |
| talkToTheHat |
| Val |
 Val World Chat Champion
 Posted: 00:50 - 04 Sep 2015 Post subject: |
Yes I can confirm there is a pretty good reason - you do not want to chase your bike in a parking lot.
I am sure that will never happen to you, but to be on the safe side wear a camera so that you can post it for us to laugh later  ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 08:28 - 04 Sep 2015 Post subject: |
The only time I don't keep it in gear, is when I park it in my garage. When I leave the motorcycle out, I keep it in gear. It makes me think the motorcycle won't move, if on a slope, or that if someone tries to steal it, it gives him another couple of seconds, or minutes to fiddle with it before he takes off.
I've got the ''GP'' gear shifter pattern, 1 up, 5 down, so a potential thief would kick it down to the 6th gear, then try to find neutral and so on. But that's not really the point. I keep it in gear because of the slope thing.
The '88 GPz 550 could start and go with the gear in and the side stand down. It made me try whether there is neutral or not. Just sit on the motorcycle, and move it forwards and back a bit, to check. It also taught me to check the side stand is up, when I ride.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Baffler186 |
 Baffler186 World Chat Champion
| MCN |
 MCN Super Spammer
| weasley |
| RhynoCZ |
 Posted: 11:35 - 04 Sep 2015 Post subject: |
What are you talking about, MCN?
The kill switch on the right handlebar is there, so you could keep your hands on the bars while turning the engine off, which is much safer, than turning the engine off using the key. That is also why manufacturers put the start button on the right handlebar, so you could have your hands on the bars all the time. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
| doggone |
 Posted: 12:58 - 04 Sep 2015 Post subject: |
In practice it's not unusual you want to hold the front brake and clutch as you stop, there's no reason not to use it 'because it might wear out'
Provided you remember to switch it on again ...  |
| MCN |
 MCN Super Spammer
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| RhynoCZ |
 Posted: 14:52 - 04 Sep 2015 Post subject: |
| MCN wrote: | | RhynoCZ wrote: | What are you talking about, MCN?
The kill switch on the right handlebar is there, so you could keep your hands on the bars while turning the engine off, which is much safer, than turning the engine off using the key. That is also why manufacturers put the start button on the right handlebar, so you could have your hands on the bars all the time. |
And if you fall off and need to use the kill switch where do you keep your hands for safety? |
If think it's time for you to stop. The kill switch on the handle bar is not emergency use only. There are only 4 positions of the key, LOCK, P, 0 and 1. So if I want to turn off the engine, yet keep the power ON, what should I do?
If you want to have an piece of equipment, that would turn the engine off when you fall off, then you should get one of these...
https://www.sohoo.cz/foto/P1020895.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| MCN |
 MCN Super Spammer
| Marlin |
 Marlin Two Stroke Sniffer
The last post was made 11 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
