(RESOLVED) Biker Newbie needs your help!!
xeningti
PostPosted: 21:37 - 03 Sep 2015    Post subject: (RESOLVED) Biker Newbie needs your help!! Reply with quote
Ok so i am not a biker as such the bike in question is a peugeot vivacity50 CC!!
Any help on this would be appreciated.
I have had the bike for a month now and apart from going really slow on hill starts (i normally have to take a runner at the big hills to get up them) its been perfect.
So today i took a runner up this very steep hill!!!! and almost nearing the top (its a bit of a tensemoment) all of a sudden i hear this loud POP (not sure if it came from engine or exhaust but it came from the back so i am assuming its the exhaust. And that point the bike lost all power and i had to pull over.
I went on with my business as i was running late and came back to drive the bike home tonight it started perfect and runs beautifully so i thought it was maybe a backfire because of the stress of going up such a steep hill.
But now when i am on even a slight incline at more than 1/2 throttle the bike just loses power for a split second then jumps back to life again.. sometimes it loses power completeley and i have to twist the throttle to get the power back on...
Does any one know what this might be? the only thing i have checked is the fuel level (it has no guage just a light) and there is plenty of gas and 2T oil. Have also checked the lead is securely ontop of the spark plug and it is...
Please help!
MCN
PostPosted: 22:18 - 03 Sep 2015    Post subject: Reply with quote
It's not correct for it to not be able to get up any hill on a public road. It will go slow but it should still make it. Eventually.
Unless you weigh 15+ stone.
Are you sure the choke lever is off (if fitted).
With choke on it is possible it will run on level ground as there is less load to move but if you point it at an incline it may die as there will be no air to burn petrol to provide the horsepowers.
Is it a new beast or 2nd hand? May be worth a visit to the dealer if there is any warranty on it.
xeningti
PostPosted: 22:26 - 03 Sep 2015    Post subject: Reply with quote
i dont know about a choke level but it had been going up all hills untill that loud bang today.... i think it must have f**ked something
Papa Lazarou
PostPosted: 07:28 - 04 Sep 2015    Post subject: Reply with quote
Probably not-probably just a backfire.
Something's up-fuelling or timing.
As has been said, has it got a manual choke? (usually a little lever on the handlebars or near the carburettor that changes the air/ fuel mixture when the engine is cold).
If you're not sure, do you have a friend or know someone who could take a look?
xeningti
PostPosted: 08:51 - 04 Sep 2015    Post subject: Reply with quote
i had a look online from what i can see its automatic on my bike.
there is one thing i forgot to mention though!!! 3 days prior i took it to a jet wash because i live in spain and we always get this horrible dust so i sprayed the whole bike... could it be that water somehow got into the system? i dont see that as the issue as the bike ran perfectly for three days up untill now????
Papa Lazarou
PostPosted: 09:13 - 04 Sep 2015    Post subject: Reply with quote
Could be water in the fuel-depends where you sprayed it. That would explain a lot.
xeningti
PostPosted: 09:20 - 04 Sep 2015    Post subject: Reply with quote
pretty much everywhere! Sad
Papa Lazarou
PostPosted: 09:23 - 04 Sep 2015    Post subject: Reply with quote
Aha.
You have two choices:
A) Drain the carb of any fuel/ water.
B) Run it like it is until the problem stops.
xeningti
PostPosted: 09:36 - 04 Sep 2015    Post subject: Reply with quote
Papa Lazarou wrote:
Aha.
And what if it doesnt stop?? its just can water in system be the cause of that huge bang going up the hill? and im thinking that this bang has been the starting cause of the problem now. i just dont see what could be cause the bike to completely lose drive up the hills and then kick back in again its like its bogging ...someones turning the power off then back on again!
Papa Lazarou
PostPosted: 15:10 - 04 Sep 2015    Post subject: Reply with quote
drain the carb (should be a screw at the bottom of it). Squirt carb cleaner in it. Start it.
xeningti
PostPosted: 15:15 - 04 Sep 2015    Post subject: Reply with quote
ok do i need any specialist tools to access the carb sorry i have no clue about bikes!
fatjames
PostPosted: 16:41 - 04 Sep 2015    Post subject: Reply with quote
Search on google for a haynes manual. I know this doesn't sound all that helpful, but it will have a section on the carb and will tell you what tools you need.
However, a half decent socket set, a few spanners and a few screwdrivers will most likely be adequate.
Can you see the carb? If not, start taking some plastic panels off until you can. The drain screw should be easy to find will definitely be at the bottom of the carb.
Here's a generic picture which might be of some use - https://www.scootertherapy.com/spreecarb.jpg
Papa Lazarou
PostPosted: 16:57 - 04 Sep 2015    Post subject: Reply with quote
Manual here:
https://www.manualslib.com/manual/893807/Peugeot-Vivacity.html
xeningti
PostPosted: 17:01 - 04 Sep 2015    Post subject: Reply with quote
Papa Lazarou wrote:
thank you so much
i might just go ahead and give it a good ol service i can read this manual and get togrips! i just hope it fixes the problema and its not something more sinister
Papa Lazarou
PostPosted: 17:04 - 04 Sep 2015    Post subject: Reply with quote
Papa Lazarou wrote:
You'll need page 35 (check the fuel filter to make sure it's not blocked) and page 42 on.
Going back to your original post, it has become clear that the carb isn't getting enough fuel.
xeningti
PostPosted: 17:16 - 04 Sep 2015    Post subject: Reply with quote
ok looked at the manual toooooo technical
Sad
fatjames
PostPosted: 17:20 - 04 Sep 2015    Post subject: Reply with quote
Sad
Buddy, it will only be difficult once. Then it will be easy. Just take your time. Oh, and take photos to help you put it back together. Keep any screws/ bolts etc safe.
Papa Lazarou
PostPosted: 17:22 - 04 Sep 2015    Post subject: Reply with quote
Sad
S'not. Look at the pictures! They'll tell you all you need to know-as I said, page 35 for the fuel filter and where it is (if it's got water in it or is all grunged up with brown stuff-change it. Just unplug it from the fuel hose and stick a new one in. That could be job sorted-cheap and easy, just remember to turn the petrol tap off first!).
Pages 42 etc for piccies of the carb. The screw at the lowest point of the carb-on the side or at the bottom-is the bleed screw. Again, turn the petrol off first.
The same site has an owner's manual too.
xeningti
PostPosted: 17:23 - 04 Sep 2015    Post subject: Reply with quote
fatjames wrote:
Sad
i mean checking the filter etc looks easy enough
but the diagram of the carb just threw me off !
Papa Lazarou
PostPosted: 17:24 - 04 Sep 2015    Post subject: Reply with quote
The bottom screw, that's all you need.
MCN
PostPosted: 17:32 - 04 Sep 2015    Post subject: Reply with quote
The Easy-Learn may be to try it with the book and with help from the forum goorooz.
Or The Hard-Learn will be how much a mechanic charges to chase a fault. Shocked
Papa Lazarou
PostPosted: 19:40 - 04 Sep 2015    Post subject: Reply with quote
The problem could be something worse. But try the easy stuff first.
xeningti
PostPosted: 22:00 - 04 Sep 2015    Post subject: Reply with quote
i might just cut my losses and take it to a garage.
xeningti
PostPosted: 16:47 - 05 Sep 2015    Post subject: My bike went bang Reply with quote
Ok so i went and got myself a socket set and had a good look round the bike!!!!!!.....
I got the seat and all the panels off.... i checked all the tubes and wires they all seem fine no cracks and no splits... i also checked what i beleive to be the fuel pump or filter (it looks like a little clear plastic reservoir on the fuel line) and inside was an amber color (also no air pockets or bubbles).... so i imagine thats good?
The Carburetor........ there was no way i could get to it as the two screws were obstructed by many other things that i didnt want touch so i will leave that for now...
AIR INTAKE... so something interesting i found when i took the filter housing on.... who ever had the bike last has cut a bit of foam/sponge the shape of the housing and used that as an air filter....... could this maybe be causing some of the problem?? i asked my friend and he suggest throwing it away...
Any other suggestions?
Papa Lazarou
PostPosted: 17:06 - 05 Sep 2015    Post subject: Reply with quote
Amber is probably okay but new a fuel filter is clear/ white.
The piece of sponge or whatever is the air filter. Is it dirty?
I'd suggest keep running it to see if the problem sorts itself-which it may not.
Can you afford to take it to a garage? If so, that might be best. It does sound like a fuelling problem, possibly caused by water getting into the fuel.
The last post was made 11 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 127.98 Kb
