How much can the battery take?
DrSnoosnoo
PostPosted: 11:14 - 04 Sep 2015    Post subject: Reply with quote
I would suggest that the alarm need not be worried about.
It won't ever be on/armed when you're running the other items.
Other than that, you need to tell us what power the sat nat needs, what power the heated vest needs etc. Quote max. power.
c_dug
PostPosted: 11:15 - 04 Sep 2015    Post subject: Reply with quote
As far as I'm aware it's not really the battery but the alternator output you need to be checking.
MCN
PostPosted: 11:17 - 04 Sep 2015    Post subject: Reply with quote
Lights will be the biggest load which can overload the charging system.
You need to find out what the normal load is on the system and what you can add.
Measure the normal load using an ammeter connected in series between the battery positive and the red main battery lead.
12v socket depends what you plug into it.
Heated vest about the same as heated grips probably not more than 1.5 amps.
Grips as heated gear 1-1.5 amps.
Satnav negligible/insignificant.
Alarm not much with engine running but they are a constant drain which should be suported by an optimiser if the machine is left for a few weeks. I use these. Charger
Inforad?? WTF is oneof them?
PostPosted: 11:29 - 04 Sep 2015    Post subject: Reply with quote
Replace your indicator, tail, side and dash lights with LEDs, stop being a beta fag.
Wonko The Sane
PostPosted: 12:53 - 04 Sep 2015    Post subject: Reply with quote
MrGs1 wrote:
TomTom rider 2013 is the Sat nav.
Kies heated vest and gloves.
takes very little power, 5a if you're using the high power bodywarmer and the gloves combined - I am going to call you a wuss for the vest however Smile
MCN
PostPosted: 13:00 - 04 Sep 2015    Post subject: Reply with quote
You're a wuss for using electronic ignition, disc brakes, padded seat, a visor, clothing, etc etc etc. Smile
Wonko The Sane
PostPosted: 13:09 - 04 Sep 2015    Post subject: Reply with quote
Ride free, ride naked?
When I were a lad, all we had was a 1912 BSA frame and a bit of foam mattress to do as front suspension and a plank of wood fer me arse...
Val
PostPosted: 13:27 - 04 Sep 2015    Post subject: Reply with quote
You can do the math.
2002-2003 have better alternator 14V/21A the old ones are 12v/18A.
Means new ones are 14x21=300W and the old ones are 12x18=216W
All at 5000 rpm. Means at 1000 rpm will be about the half.
Here are Common Operating Loads
High Beam 55 watts
Low Beam 55 watts
Number Plate 5 watts
Brake/Tail 21 watts
Instrument Panel 2 watts
Computer 25 watts
Fuel Pump 60 watts
Cooling Fan 60 watts
Electronic Ignition 50 watts
Do the math depending on have you got connected.
If you exceed the power too much bad things will starts to happen - melting cables, fuses blown etc.
The way I see it no way you can connect all that, think about running some stuff on its own batteries. For example there is heated clotes that have batteries, and for the sat nav and other stuff you can buy one this external power banks will be good for your sat nav about 10-20 hours depending which one you get:
https://www.amazon.co.uk/dp/B00SR5N5HU?psc=1
https://www.amazon.co.uk/dp/B00A0NALHE/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B00FBD3MVA&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=19Z0TTC43D81AGCTN3M0
MrGs1 wrote:
Inforad. ??W
Heated vest 70W/gloves 80W.
Heated grips 60W?.
Power point to charge sat nav.
Spotlights 2x30W??.
Alarm ??W.
About the alarm - the worst idea ever. They fail and when it fail, it will beleive me, you got stuck in the middle of nowhere.
IMO you will be much better with disc lock alarm like Zena:
https://www.amazon.co.uk/Xena-XX14-Disk-Lock-Alarm/dp/B003DXCHAM
orac
PostPosted: 14:36 - 04 Sep 2015    Post subject: Reply with quote
heated gloves I kinda get, but heated vest. layer up, I have ridden in -15c with wind chill @ 60mph, I have worked bare handed in -12C.
then the other maddening thing, why heated gloves and bar grips? that more pointless than anything I can think of as a comparison. I cant see heated grips warming finger tips (unless you grip the bars too tightly) so go for the gloves IMHO.
drop the inforad and learn to observe. scrap the alarm as everyone else has said. LED spots are about 15w each, so 2 is 30 total
so heres what you need
GPS: 12W - at a guess
Heated Gloves: 60W
Layers of clothing: 0W
LED Spot lights: 30W
Phone Charger: 30W - or decent phone that doesn't need constant charging
A dose of man the fuck up: 0W
Not running all them at once: common sense
MCN
PostPosted: 15:02 - 04 Sep 2015    Post subject: Reply with quote
Heated Gloves: 60W
Heated clothing is a personal choice.
Layers mean layers. They can restrict movement. A heated vest is one layer you can switch on or off or if it's posh enough set the ideal temperature.
Layers are an arse when you warm up or the weather warms up. Where do you stow them?
Heated gear works.
Though layers can be cheaper if your budget is a concern.
A heated vest will not take much more than grips 1-2 amps 12-24 James Watts.
Yes one must also not overload the alternator.
kramdra
PostPosted: 15:27 - 04 Sep 2015    Post subject: Reply with quote
Fz6 generator should be capable of ~450w, same as any big bike. Its a large lump of oil cooled metal, with a good 100 degrees between oil temp and maximum temp, more in winter.
As most regulators are the shunt type, you'll be doing the generator a favour by drawing more load, less heat for it to dissipate. Worth checking your regulator has adequate air flow, check the wiring and connectors, it will be fine. Connect everything on a relay as you dont want it left on draining battery.
You could also get a cheap voltmeter, also connected through relay. https://www.ebay.co.uk/itm/121457129678 Seal it in epoxy + coat of black and put by your clocks.Under 13.5v while running is not going to be charging, turn some stuff off... .
There are also many cheap constant voltage/current/step up regulators on ebay, which will let you set lights/heat exactly where you want it. The controllers on heated gear, usually shit.
phone charger will be 10-12w max, unless you have a poor efficiency linear regulator type, or intend multiple phones!?!?
Inforad is rubbish, dont get one.
MCN
PostPosted: 16:27 - 04 Sep 2015    Post subject: Reply with quote
MrGs1 wrote:
Power point - Will be used occasionally on longer runs when I need to keep my sat nav/phone charged.
Inforad - Not yet fitted but I will come to my own co conclusion whether or not I will keep it on the bike thanks. It cost the quater of what a fine so even if it saves me just once in an unfamiliar known scamera van zone it has paid for its self.
Heated equipment - I will use daily on longer runs in the colder months.
Heated grips - I will use when it is wet in conjunction with muffs and or if there isn't suitible storage at the other end of my journey for all my shit.
Spotlights - Required so I can see where I am going FZS box eye lights are shit.
Alarm - Despite what arm chair experts whitter about I have never had a problem with just a solo alarm (not the immobiliser ones).
Note - The above will obviously not all be running at once bar the inforad and heated gloves/vest or grips not both.
So will the battery take it?
Yes the battery will drive all that stuff. The Fazer should be able to top up the battery too.
I have an Evolution Radar GPS scammera detector. It was fitted and I still got a feckin ticket. Embarassed If there's an extra sneaky scammera van points towards your arse then the radar/gps won't alert. That's if you are paying attention to it. They are hopeless on a bike as you can't here the bleeps easily without head set connections and phaphery.
I know you get some with flashing lights but phaphery again.
I fitted a USB socket to my K1300 for phone/iPod charging.
12v USB Socket
Papa Lazarou
PostPosted: 17:07 - 04 Sep 2015    Post subject: Reply with quote
Try upgrading the headlight bulbs before fitting spotlights.
MCN
PostPosted: 17:26 - 04 Sep 2015    Post subject: Reply with quote
MrGs1 wrote:
Already have with mediocre results.
The brightest I have found. Used on my bikes and cars. Phillips claim to make brighter bulbs (for £30+ a pop) but PIAA is a 'better' light Thumbs Up
https://www.piaa.co.uk/bulbs/bulbs.asp
A bit ££ and not a lot of dealers but worth a punt.
Spots can be a cnut when you have to find mounting points and weatherproof wiring/switching.
The last post was made 10 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 108.08 Kb
