Anyone Know The Make Of This Master Cylinder
Fizzer Thou
PostPosted: 17:34 - 04 Sep 2015    Post subject: Reply with quote
As the bike in the pic looks like a GT750 (the temp gauge between the speedo & tacho are a giveaway) I would suggest this is what you are looking for Thumbs Up
https://www.robinsonsfoundry.co.uk/content/pages/shop/parts/Suzuki/GT/GT750%20Kettle/J%20K%20L%20M%20A%20B%20(1972-1977)/gt750frontmastercyllmab.htm
Always have a 'Plan B'
Ed Case
PostPosted: 19:29 - 04 Sep 2015    Post subject: Reply with quote
Tokico by the look of it.
Ed Case
PostPosted: 21:09 - 04 Sep 2015    Post subject: Reply with quote
Vincent wrote:
Is that a stab in the dark with good odds, an educated guess... or from experience?
If it's wrong, will you buy me another? Very Happy
Looks very much like that fitted to the SOHC Honda 750's.
Fizzer Thou
PostPosted: 09:46 - 05 Sep 2015    Post subject: Reply with quote
I do not ever remember seeing a GT750 without a second disc,even when Bike magazine tested the bike alongside a CB750F1 all of those years ago when they were first introduced.So if you get firm pressure when using that master cylinder,why suspect that it would not be good enough?
The comment about the master cylinder looking very much like one from a Honda four was what I was thinking,except for the ridged bit where the banjo bolt goes into the master cylinder.Presumably this is where the rubber boot goes over and is held in place by the ridge.But I have never seen this on similar Honda four master cylinders and I have had quite a few.
This pic from a 1976 Honda catalogue shows a similar looking master cylinder which also looks like the one fitted to a CB550K3 with the white plastic part.But the one shown in Vincent's pic shows a ridged plastic part,which the Honda ones did not have.
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Snaps/HondaLeaflets005.jpg
This pic of a CB750SS (essentially a CB750F2 dressed up by Colin Seeley) shows the standard master cylinder for that bike,feeding the standard double front discs.The master cylinder itself was very similar to the one on the CB550K3 except with a taller reservoir.
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Snaps/HondaLeaflets022.jpg
I had a twin disc conversion on one of my CB550s and used the standard master cylinder,except with Aeroquip hoses and Ferodo brake pads.With careful bleeding the brake was effective enough to lock the front wheel (45 in a 30 Crying or Very sad )
Fizzer Thou
PostPosted: 16:26 - 05 Sep 2015    Post subject: Reply with quote
I have looked through countless images of the GT750K (the original disc braked Kettle) on goggle images and not one has a single disc.
But....
The original wire spoked GS750 came with a single front disc,with the option to go with a second disc that Suzuki quickly included as standard,due to the success of the bike in proddy racing.
While looking for images on photobucket for a standard early model GS750 I found this picture of a Suzuki master cylinder Wink
https://i88.photobucket.com/albums/k171/Wreckamundo/1978%20Suzuki%20GS750%20Parts/Master.jpg
https://i563.photobucket.com/albums/ss73/dksparesebay/Neils%20Bikes%203/DSC00857.jpg
https://i563.photobucket.com/albums/ss73/dksparesebay/Neils%20Bikes%203/DSC00849.jpg
Fizzer Thou
PostPosted: 18:36 - 05 Sep 2015    Post subject: Reply with quote
With a second disc you are only moving the fluid within the system a very small amount ie. that distance that the disc pads have moved away from the disc when you let go of the brake lever.You might get slightly further lever travel,but as I found with the modified CB550,with careful bleeding and other modifications the difference was minimal.
PostPosted: 19:58 - 05 Sep 2015    Post subject: Reply with quote
Also possible that they fitted a large bore m/c as standard and just let those with a single disk put up with dead feeling brakes needing loads of pressure.
K
smegballs
PostPosted: 23:40 - 05 Sep 2015    Post subject: Reply with quote
Vincent wrote:
I think the problem's solved, someone on the kettle club has told me it's too small for dual disc anyway. I think the extra disc was optional and it sounds like Suzuki didn't bother to upgrade the M/C when you had it fitted Very Happy
Sounds like a similar situation to the XS650 my dad had.
The massive 16mm bore master cylinder it had fitted was way oversized for the single-pot, single-disc it had and as such the lever was rock hard and the brakes did fuck all.
I ran the numbers for fun and the 16mm M/c would have been just right for the twin disc setup that some XS's had.
I think sometimes the manufacturers just chuck on whatever is left over from other models....
Take my GN: Stock m/c is 14mm bore, lever hard and brakes weak. I downsized to a 12mm one from a R125 and that one swap transformed the brakes: powerful with a nice progressive lever feel. With the same stock shit single-pot caliper, disc, pads etc
Obviously the m/c is much easier to swap out than calipers etc between models, so I think people could benefit a lot by making sure the calipers and m/c are matched properly if they suffer from 'shit' brakes.
The last post was made 11 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 104.31 Kb
